My shark is dead
Old Aug 25, 2001 | 11:11 AM
C3Vettesrock's Avatar
C3Vettesrock
Default My shark is dead
Its not dead, but I'm not sure whats wrong. Cranked it up, put it in reverse, backed up about 2 feet and it killed, now it wont start. Carb is spraying gas, ignition is working....what else could be wrong besides it jumping timing?
help
Old Aug 25, 2001 | 01:38 PM
CharlieF's Avatar
CharlieF
Default Re: My shark is dead (C3Vettesrock)
are you sure the spark is good? Your coil could be bad but still giving you a weak spark. Happened to me....
Old Aug 25, 2001 | 01:44 PM
rrent's Avatar
rrent
Sounds like it might be a no spark situation - I've had rotors on HEI's get a pin hole in them and give the same indication.
You gotta have air/fuel (correct ratio) and spark (at correct time) - if you've checked the spark and its good, you should be able to tell if the carb is dry or way over rich after a bit of cranking - then it might be the timing - as simple as the distributor hold down loose or like you mentioned timing chain problem.
good luck
To My shark is dead
