81 Corvette running hot......
Old May 21, 2006 | 11:38 PM
jmchutchion's Avatar
jmchutchion
7th Gear
Default 81 Corvette running hot......
I bought my second Corvette about a month ago. Its an '81 and it runs hot. It warms up quickly and gets up to about 220 degrees after about 15-20 minutes on the highway (at about 3000-3500 sustained RPM). Will start to drop slowly if I turn AC off. Is this normal for this model? Help please!!!!!!!!!!!!
Old May 21, 2006 | 11:49 PM
blackcorvette1980's Avatar
blackcorvette1980
Check your electric fan and make sure it is working. All 81s have one (electric fan) and it should turn on about 210 and keep it below 220.
Old May 21, 2006 | 11:52 PM
sperkins's Avatar
sperkins
Your problem could be a number of things. However, based on the fact that you said it runs hot on the highway, the first thing I would check would be distributor advance system. If your centrifugal (mechanical) advance and/or vacuum advance is not working properly, it will make your engine run hot while cruising at highway speed because it is not achieving the proper advance needed under those circumstances. Use a timing light to see if either one is not working correctly.
Good luck!
Old May 21, 2006 | 11:56 PM
jmchutchion
7th Gear
Thanks, I'll check that out.
Old May 21, 2006 | 11:58 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Things to check:
Fan clutch
Electric fan
Radiator -- clean inside and out.
Radiator seals.
Lower radiator hose - is it colapsing at higher RPMS.
Temp gage - is it reading correctly.
Carb - too lean ?
Timing - is is right ?
Old May 22, 2006 | 12:04 AM
SIXFOOTER's Avatar
SIXFOOTER
81 has ecm controlled dist/timing. If the car runs good and accelerates strong there is nothing wrong with the timing. Retarded timing will make it run hot but will also exhibit weak power. The electric fan is an aux fan and I didn't find it very awe inspiring as far as a cooling helper, it does its job best in traffic, slow driving.
Look at the Air Dam below and in front of the Rad. Most of these cars have been run onto parking curbs ans whatnot which will push the air dam out of shape. With it bent/pushed up it will not allow proper air flow thru the rad and give those exact symptoms.
I could be wrong, it happens ( a lot)
Old May 22, 2006 | 12:11 AM
gtsvette's Avatar
gtsvette
Check to see if you have the front spolier...!!!! that was my problem... it would get hot on the highway!!
Old May 22, 2006 | 12:49 AM
jmchutchion
7th Gear
I don't have the front spoiler and was reading how that was its main function, to increase air flow to rad. I bet thats its too. Thanks.
Old May 22, 2006 | 12:50 AM
gtsvette's Avatar
gtsvette
yep... that would do it!
Old May 22, 2006 | 01:06 AM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Thermostat? It may need replacing.
Old May 22, 2006 | 05:46 AM
PhotoVette1's Avatar
PhotoVette1
A thermal fan clutch will freewheel at any engine speed over 2800 rpm. It will not re-engage no matter what the temperature climbs to.
Basically you are running with no radiator fan and a large airflow blockage when you cruise at 3000+ rpm.
Late model L82's had a spring loaded flap in the shroud to allow air to flow freely on the highway and not get blocked by the freewheeling fan blades.
You can solve this problem by:
1. Installing an overdrive transmission. Or...
2. Installing a high rpm rated fixed race fan (not a flex fan.) Or...
3. Installing an aluminum radiator. Or...
4. Installing an underdrive pulley set. Or...
5. Installing a late model L82 fan shroud.
I went with the aluminum radiator from Dewitts--problem solved.
I do have the fan shroud and aux electric fan from an '81 in my '77. And it did keep the coolant temperature between 210-220 as stated. I just didn't like to cruise at 220F--it made me nervous.
The high rpm rated fixed race fan works the best and is the cheapest fix ($40-45)--air flow like you wouldn't believe (suck a deer right through the radiator.) But it's noisy and has got to hurt mpg.
Old May 23, 2006 | 01:11 AM
Steve COSD's Avatar
Steve COSD
The most common problem withe the C3s getting hot is the foam rubber seals that install between the radiator and support. If these fall out and leave a gap then the air goes around the radiator rather than through it. These are absolutely needed. Next is thermostat for your car. You will need a 180 degree and get the robertshaw brand if you can find them. Next make sure your hoses are not collapsing, this is what the spring inside helps to prevent. And even though the spring is inside this is still no guarantee that they are not collapsing. If they are old replace them. These are the basics. Hope you find your problem.
Good Luck
Steve
To 81 Corvette running hot......
