New distributor recommendation....
Old May 23, 2006 | 09:56 PM
Joes80's Avatar
Joes80
Default New distributor recommendation....
I need a new distributor.....nothing special, for a 1980 GM 350 crate. Old one out, new one in, hopefully it's that easy. Any recommendations?
thanks
Old May 23, 2006 | 10:49 PM
Bangkok Dean's Avatar
Bangkok Dean
If you can find a new GM unit that is the best I can say. I used a Summit and have had real problems with it. If I could go to a Chevy dealer I would have but they don't have such a thing over here.
Old May 23, 2006 | 10:57 PM
jeckel's Avatar
jeckel
Accell makes a nice HEI Dist that is a stock replacement. The cost is pretty low and it will give a nice perfomance increase as well IMHO.
Old May 24, 2006 | 12:00 AM
midyear1's Avatar
midyear1
For use with non-ecm applications:
http://store.summitracing.com/compar...256+115&Nao=70
Old May 24, 2006 | 06:20 PM
PartTimeGenius's Avatar
PartTimeGenius
I've heard some positive things about these guys
http://www.performancedistributors.com/
Unlike Accell, Mallory, MSD etc, they actually set each individual advance curve to work with your particular car. Plus, I think they're having a sale on Chevy HEIs.
Check 'em out!
Old May 24, 2006 | 06:56 PM
fugawi's Avatar
fugawi
mallory has a nice one i installed in my 74 pickup. at summit racing the number is maa-8548201c
Old May 25, 2006 | 08:19 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Check 'em out!
I have used DUI on two cars.
I have thier HEI with tach drive in the vette now. great company good service. send them you engine specs , the will set up the unit on a distributor machine and all you have to do is hook up the wire and go
noticed an immeditate difference. this prices are on the top end, but you do get the extra service of the custome set up
Cheers
tim
Old May 25, 2006 | 04:36 PM
halfmoontrail's Avatar
halfmoontrail
Salvage yard, 74-79 chevy HEI distributor, probably around $25.
I'll probably get flamed on this one, but...I'd be very surprised if there is any true measurable performance difference between a stock HEI distributor and any aftermarket one, assuming same advance weights/springs and vacuum can.
Steve
Old May 27, 2006 | 04:03 PM
Joes80's Avatar
Joes80
There is one from Ecklers...Corvette Distributor, With Vacuum Advance, Hi-Performance HEI, 1975-1980...139.99. My motor is mostly stock.....should this one be fine?
Old May 27, 2006 | 05:45 PM
jdmick's Avatar
jdmick
Steve
No flame here. Use the stock weights and a Mr. Gasket curve kit with lighter springs and new bushings and you'll be good to go. Just make sure everything moves freely. If you feel like spending some money you could replace the pickup coil when you have it out for extra insurance and carry a spare module.
To New distributor recommendation....
