Home built spreader bar
Old May 28, 2006 | 07:00 PM
  #41
litevette's Avatar
litevette
Is this it?
http://cgi.ebay.com/1984-CHEVY-POWER...QQcmdZViewItem
Old May 28, 2006 | 07:18 PM
  #42
Socket Head Bolt's Avatar
Socket Head Bolt
Originally Posted by litevette
Old May 28, 2006 | 07:44 PM
  #43
litevette's Avatar
litevette
Thanks! I've sent the seller an email.
Old May 29, 2006 | 09:18 AM
  #44
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default new pics
took a couple of new pics this morning. Top view drivers side a-arm mount Looking from fan to d-side a-arm tight fit between fan and w-pump pulley A couple more on link in earlier reply.
Old May 29, 2006 | 10:22 AM
  #45
BerniesVette's Avatar
BerniesVette
Great pics showing that the bar will fit with the stock fan installed. It is a tight fit, but what isn't on a C3! Deflection is kept to a minimum. Can you feel any difference with it installed?
Bernie
Old May 29, 2006 | 01:44 PM
  #46
c69vete's Avatar
c69vete
St. Jude Donor '07
I feel like there is a big difference in the way the car feels going down the road and around corners as well. Note that the tie bar is bolted 1" below the bolts of the a-arm. Thats why the 2'' base plate.
Old May 29, 2006 | 04:01 PM
  #47
Jclgodale3's Avatar
Jclgodale3
What guide did you use to pre-tension it? How much tension "twisting out" did you apply between the shock towers? Here's an updated picture of my brackets. Installing today.
Old May 29, 2006 | 06:00 PM
  #48
BerniesVette
I will adjust mine so there isn't any play in it. Just tight without changing the camber.
Bernie
Old May 29, 2006 | 06:03 PM
  #49
Socket Head Bolt
It looks like you just tacked them in.
Old May 29, 2006 | 06:06 PM
  #50
c69vete's Avatar
c69vete
St. Jude Donor '07
With the car on the ground in normal driving mode, just turned the bar out BY HAND till it would turn no more. Lock down the jam nuts and you are good to go. If you use a wrench or set it while it is jacked up you will have to get the front end re-aligned. All you want to do is hold things in place.
Old May 29, 2006 | 06:31 PM
  #51
Jclgodale3's Avatar
Jclgodale3
Um...no. I just cleaned up my welds. I'm new at welding
Old May 30, 2006 | 12:03 AM
  #52
Jclgodale3's Avatar
Jclgodale3
Thanks Bernie and c69. Thats what I'll do when the heims get here.
Old May 30, 2006 | 11:10 PM
  #53
Jclgodale3's Avatar
Jclgodale3
TTT for final install pics. It's done!
Old May 31, 2006 | 07:57 AM
  #54
BerniesVette
Looks great!
Bernie
Old May 31, 2006 | 07:11 PM
  #55
Jclgodale3's Avatar
Jclgodale3
Originally Posted by BerniesVette
Looks great!
Bernie
Thanks Bernie...yours was the inspiration for me. Tell me...what differences should I be able to tell from driving it with this installed and tensioned vs not installed? Just wanna know what to expect
Old May 31, 2006 | 07:13 PM
  #56
Socket Head Bolt
It's a real PITA unscrewing the bolts that hold the upper a-arms on. They are the oblong ones that don't loosen very good.
Old May 31, 2006 | 07:44 PM
  #57
Jclgodale3's Avatar
Jclgodale3
Not sure I am following what your trying to tell me
To Home built spreader bar
Old May 31, 2006 | 09:26 PM
  #58
BerniesVette
Norval and I talked today at lunch. He turned his until the bar was just pushing out on both sides and tightened both jam nuts. He did not turn the rod until the castor or camber was changed; just spread the bar until it was tight. I am waiting on my brackets to come back from being powder coated. The comments I get from Norval and others is that the front suspension feels tighter with more control. For 50 to 60 bucks, and some fun building the bar it sounds as if it is worth it. A large part of the satisfaction I get from owning the Vette is what I do to make it better and how I want it. Better handling, self satisfaction, and a more responsive, safer and reliable car makes it all worthwhile!
Your install looks great; I hope mine looks half as good!
Bernie
Old May 31, 2006 | 10:08 PM
  #59
c69vete's Avatar
c69vete
St. Jude Donor '07
mine feels tighter with the bar. Doesn't feel like it flexes as much going around corners. Big improvement for the bucks. Yours looks good. be sure to post what you think after you try it out.
Old May 31, 2006 | 11:29 PM
  #60
Jclgodale3's Avatar
Jclgodale3
I absolutely agree and people like you all including Norval, TT, Jug and others make it all so much easier to accomplish and
