Center instrument cluster-light
Old May 24, 2006 | 10:40 AM
Urban Cowboy's Avatar
Urban Cowboy
4th Gear
Default Center instrument cluster-light
Presently I'm restoring a 1970 coupe. I'm trying to keep it as original as possible. After rebuilding the center instrument panel when it was reinstalled and tested I found that I cannot keep the fasten "seat belt" light from coming back on. When the button is pushed the light will go out but will re illuminated after releasing. I know there is a holding coil that is designed to engage which keeps the light from re illuminating. This might be the problem, the question I have is where can I get a replacement. I can not find one. Any help is appreciated.
Old May 24, 2006 | 02:42 PM
Petes73's Avatar
Petes73
which button are you pushing? on my 73 if you disconnect the belt(release the button?) the light comes back on.
Old May 24, 2006 | 03:31 PM
Fstdraw's Avatar
Fstdraw
Check the Corvette mags. I found my replacement at Pacific Corvette in Portland, OR. Easy to deal with, and they'll ship to you. Ask for Jim. Phone is (503) 239-0210.
Old May 24, 2006 | 08:46 PM
Urban Cowboy
4th Gear
Thanks for the response. From what I can determine the 1970 fasten seat belt light is nothing more than an idiot light. Even if you have your belts fastened the light will still illuminate and only go out when you push the button in on the center gauge cluster.
Old May 25, 2006 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Urban Cowboy
...From what I can determine the 1970 fasten seat belt light is nothing more than an idiot light. Even if you have your belts fastened the light will still illuminate and only go out when you push the button in on the center gauge cluster.
Ditto for the '68. Push it and it goes out.
To Center instrument cluster-light
