Battery Cables
Old Aug 25, 2001 | 09:32 PM
classicguy's Avatar
classicguy
Default Battery Cables
My 82 has side-mount battery cables is that the correct style for my year. Not that care about it haveing to be factory. But I do have a problem with then constantlly looseing. and I always get that familiar gunk when I go start the car (this regreetable always happens when there people around saying nice car) have to get out fiddle with the cables tighten them get my hand all dirty with some sort of gue that in there. :rolleyes:
Old Aug 25, 2001 | 10:10 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Battery Cables (classicguy)
I would check at a local parts store to see if they can recommend a locktite lube that might help prevent your terminals from loosening. Be sure your battery is locked down tight so that it isn't moving around while your driving.
Old Aug 25, 2001 | 10:11 PM
Jvette73's Avatar
Jvette73
Clean the connections up with wire brush real good . Might need to pull battery out of car to do so. A light coat of vasoline on the terminals will help reduce corrosion. You can get new terminal post screws from typical discount auto stores.
my 73 has side post battery mounts come to think of it. Aint htat wierd?
[Modified by Jvette73, 8:14 PM 8/25/2001]
Old Aug 25, 2001 | 10:25 PM
SmokedTires
St. Jude Donor '05
Default Re: Battery Cables (Jvette73)
My 74 also has the side mounted battery in it, don't know if it came that way though :crazy:
Old Aug 25, 2001 | 10:28 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Battery Cables (mikeo)
Side mounted cables became standard in mid 69 model year.
Old Aug 25, 2001 | 10:33 PM
trw's Avatar
trw
Side mounted in mine also.
Old Aug 26, 2001 | 09:04 AM
Tim80's Avatar
Tim80
I have the same problem with my 80. I am interested in all responses too.
To Battery Cables
