Big block half shafts
Car will only ever run street 255 yoko tyres, may try it one or two times at strip, but essentially its a street car.
Looking for easy upgrades on the half shafts as I hear the unis are weak links. Present unis have grease points. I read that weakens them. Does anyone know the correct part and # to replace them with something stronger?
I see the dragvette site lists 3" half shafts (when available). Are these shafts likely to be better than mine? Do I need a better shaft or just a better uni? Freight on items like this to Australia will be more than the item, so if I could just replace the unis it would be great.
If you decide to swapout just the u-joints be careful casue the flange can bend easy, then you are screwed. that's why I suggest going with preassembled units.
