Horn Relay
Old May 26, 2006 | 10:30 AM
73383's Avatar
73383
Default Horn Relay
Has anyone attempted to rebuild a horn relay. Getting the horn working is one of the last things I have to do on my frame off. That and seat belts.
Car is a 73 and most suppliers have discontinued this item and the ones that have it want 85.00-95.00 bucks. If all else fails maybe I can adapt another relay.
Dennis
Old May 26, 2006 | 10:36 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Dennis
never tried to rebuild one, corvete central wants 50 for thiers,
any local junk yards ?
Old May 26, 2006 | 10:42 AM
73383's Avatar
73383
corvette central's is a replacement item they want 89.00. this is for a 73 model
Old May 26, 2006 | 10:52 AM
sweethence's Avatar
sweethence
just checked thier on line listing and it was 49.99... but your right it is not an original...
either way sounds like more than you want to spend
sorry
tim
Old May 26, 2006 | 11:07 AM
73 red vette's Avatar
73 red vette
Dennis
Mine is a 73 also and the horn doesn't work, I was wondering if there was a way you could get it to work by bypassing the horn relay to see if the horn will work or not, mine was bubba'd up by previous owner, and I can't tell if it is the relay or the horn just doesn't work.
Old May 26, 2006 | 11:10 AM
sfallison's Avatar
sfallison
Easy way to check the horn.. Run a wire from your battery to the horn - (check to insure the horn's ground is ok). Horn "Beep's" it's good.
My 75's wasn't working, and it turned out to be the ground (rusty).
Old May 26, 2006 | 11:13 AM
73383's Avatar
73383
yes you can bypass the relay, I did it last night.
it's not that I'm a tight wad, I've spent 30,000.00 on this car. it just galls me to pay 100.00 for a 10.00 piece.
Old May 26, 2006 | 11:16 AM
sweethence's Avatar
sweethence
I Know I feel the same when I pay 40 bucks for the inline fuel filter that used to cost 10
D&R classic hase some original AC Delco ones fro 65
Cheers
tim
Old May 26, 2006 | 11:20 AM
SIXFOOTER's Avatar
SIXFOOTER
you can rebuild it as long as the coil is not burned. Most of the time a contact dies. Pry off the top and file/realign the contacts and it will be good for a while.
Old May 26, 2006 | 11:38 AM
73 red vette
Well I am a tightwad and I don't like getting hosed on a $10.00 part. When I spend a dollar I like to get Afull $ worth of whatever I'm buying, if not a $1.10 worth. Vette parts are ridiculous in the first place, specially when the majority of them intechange with any chevy part if you check.
Old May 26, 2006 | 11:47 AM
sweethence's Avatar
sweethence
Yep, ,i am always lloking to get parts from camaor vendors, much cheeper when possible, plus i have a local vette junkyard about 15 min away
lots o goodies there
tim
Old May 26, 2006 | 02:02 PM
norvalwilhelm's Avatar
norvalwilhelm
Dennis
Guys don't mess with the relay. I tried filing the points, bending the points and it wasn't consistent.
I then called the local autoparts store and it is a stock item. $13 CDN and in stock Got a box right in front of me but the parts man should be able to look it up. Did this last week., I was actually thinking about running a post on how to trouble shoot a horn?
Numbers on the box A5J
RL32631
RELAY
Made by NIEHOFF
Not worth bothering with rebuilding the stock one.
Horn relays and brake light switches are stand auto parts inhouse stock.
Old May 26, 2006 | 02:03 PM
norvalwilhelm
$13 at your local parts store and that is worthless CDN dollars to boot. Bought one last week, they are in stock.
Old May 26, 2006 | 02:11 PM
73383's Avatar
73383
Thanks Norval
Plug is different than mine. But I should be able to make it work. NAPA has it for 10.95
To Horn Relay
