Holley float bowls
Old Aug 26, 2001 | 01:20 PM
Wrencher's Avatar
Wrencher
Default Holley float bowls
I could use some help finding a new or excellent used float bowl for my center carb. Coincidentally, my BOSS 302 also needs a rear bowl, and I find that the local performance shops all come up with 'not available' in their Holley catalogs! Both have marginal threads for the needle and seats (both these carbs have probably been overhauled numerous times ) and I would like to replace them before they fail. I seem to remember in past posts a reference to a rebiulder that everyone spoke highly of. Anyone have that address or phone number? All help would be much appreciated!
Old Aug 26, 2001 | 02:36 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Holley float bowls (Wrencher)
if it does not have the inlet on one side and the line to the rear bowl on the other any holley bowl will fit. some fords had this setup and no holley aftermarket carbs did. the only thing to look for is if the front bowl has a external vent. :chevy
Old Aug 27, 2001 | 12:36 PM
Wrencher's Avatar
Wrencher
ttt
Old Aug 27, 2001 | 12:44 PM
clem zahrobsky
Cruise-In I Veteran
the guy you want is jerry luck,check the NCRS forum. like i posted above all holley bowls are the same except for specials.
Old Aug 27, 2001 | 12:49 PM
MELVIN's Avatar
MELVIN
Default Re: Holley float bowls (clem zahrobsky)
WHILE IM NOT SURE WHAT MODEL HOLLEY (LIST NUMBER) YOU MIGHT HAVE, TRY SUMMIT. THEY HAVE A BUNCH OF BOWLS FOR HOLLEYS, ESPECIALLY THE 4500 SERIES AND BELIEVE IT OR NOT, THEY FIT THE 2300 TRI POWER CARBS. THEY EVEN SELL BOWLS THAT HAVE THE ABILITY TO CHANGE JETS WHILE THE CARB IS STILL ON THE CAR. COMES WITH NEW BOWL AND JET, SO THAT WOULD BE A COMPLETE BOWL REPLACEMENT, IF YOU HAD TO GO THAT WAY
Old Aug 27, 2001 | 12:55 PM
MELVIN's Avatar
MELVIN
Default Re: Holley float bowls (MELVIN)
WHOOPS, SORRY. I JUST REREAD YOUR POST, AND YOU NEED THE CENTER CARB BOWL. THE PROB I RAN INTO, WAS THAT I STRIPPED OUT THE CENTER CARB JET SEAT LIKE A MORON :U
I LOOKED LONG AND HARD FOR A CENTER BOWL, AND NO ONE SEEMS TO HAVE THEM. SUMMIT DOES, AND LOOK CARFULLY AT THE SECTION FOR BOWLS FOR A 4500 SERIES CARB. THEY HAVE THEM FOR LEFT OR RIGHT FULE INLET,AND WITH/WITHOUT ACCEL PUMP. BE SURE TO ORDER THE CORRECT SIDE INLET, AND WITH ACCEL PUMP/ AND YES, ITS A DIRECT FIT/FUNCTION FOR OUR SERIES 2300 CENTER CARBS :chevy
To Holley float bowls
