Transmission Assembly Problem - Pump Housing
Old May 27, 2006 | 07:41 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Default Transmission Assembly Problem - Pump Housing
After rebuilding my tranny this weekend (TH350C) I'm trying to put it back together. So far so good but I'm having trouble getting the pump housing back in. I've got two guide pins in (cut off 5/16 bolts) and I'm pretty sure that everything is in the right order, but I can't get the housing to seat. It's stuck just past the width of the housing so I'm pretty sure its internal rather than the body itself. Any tricks?
Old May 27, 2006 | 07:52 PM
windsoreight's Avatar
windsoreight
One of the drums has probably hasn't seated all the way. If you had an H gauge it would be easy to tell. Just make sure all the drums have seated all the way down. I can be a pain sometimes.
