Trans Problem
Old May 27, 2006 | 09:01 PM
wogs73's Avatar
wogs73
Default Trans Problem
Turbo 400, disengages in 3rd gear after letting off of gas. Kind of like it goes into neutral and when gas is reapplied it revs up and re-engages. Is it a valve in the valve body that is sticking or???? Fluid has been changed and it shifts perfect other than that
Old May 27, 2006 | 10:17 PM
comp's Avatar
comp
does it do it in 1st or 2nd ???? like low line pressure
Old May 28, 2006 | 10:01 AM
wogs73's Avatar
wogs73
Only in third. Shifts fine just has the disengageing in third problem
Old May 13, 2012 | 05:11 PM
Petes75Vette's Avatar
Petes75Vette
Was there ever a solution to this problem? I'm having the same issue.
If someone could advise...that'd be great!!
Old May 19, 2012 | 12:51 PM
Petes75Vette
Anybody? Bueller.....?
Old May 19, 2012 | 10:12 PM
pricesgarage's Avatar
pricesgarage
try un hooking the passing gear switch on the tans and drive it if that cures it needs a switch they get weak over time also it could be in the valve body superior and trans go has a valve body kit to fix weak springs
To Trans Problem
