1968 Starter Wiring Question ??
Old May 28, 2006 | 09:02 AM
tonyts's Avatar
tonyts
Default 1968 Starter Wiring Question ??
Finally got the engine in today. I found most info thru search but here's one - Not sure on correct wiring hookup for starter, see below, and did not mark correct.
Any help ??? getting closer to getting her on the road!
Old May 28, 2006 | 11:27 AM
GDaina's Avatar
GDaina
Black wire is ground. the red wire with the big eye goes to the 3/8" bolt, the small eye goes to the 1/4" on the solenoid. I think its 1/4 or 5/15" socket...maybe 5/16" socket.
The + wire from the coil goes to the R side on the solenoid
Old May 28, 2006 | 05:59 PM
tonyts's Avatar
tonyts
Thanks, so if I got you right the other heavy red with the small hole connector goes to the selenoid ?? or I can just ohm ou the coli wire for verification.
Thanks again
Old May 28, 2006 | 11:32 PM
GDaina's Avatar
GDaina
yes goes to the solenoid
To 1968 Starter Wiring Question ??
