ideas on no go ignition?
Old May 28, 2006 | 09:35 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default ideas on no go ignition?
Hey guys, I went to fire up the beast yesterday. New battery, started fine 9 weeks ago. Not a click or anything at the solenoid. Lights come on, gauges come on, radio comes on. Is there a relay or some switch somewhere that cuts out the current to the starter? We just did a redo on the interior all the way. Do you need to have the clutch pushed in to get ignition? Is there something we didn't get hooked up right? 72 convertible 4 speed TIA:
Old May 28, 2006 | 01:14 PM
carriljc's Avatar
carriljc
Default Clean your battery posts & terminal connections...
I kid you not; wire brush them well, make them shine.
This has happened to me several times in my old man years. If you don't know about the clutch, then just push it in and try it. If nothing else, it will eliminate that as a problem...also, ensure that they're nice and tight when you're done.
Old May 28, 2006 | 01:18 PM
carriljc's Avatar
carriljc
Default And if that doesn't work....
go get the battery load tested at your local autoparts store. Can't really tell from your message but it implies that you have not tried to start it in the past 9 weeks. IF you had some battery drain during these past 9 weeks, then you may have drained the battery. However, from the symptoms you describe (lights work, etc) it really seems like the dirty terminal issue.
Old May 28, 2006 | 01:22 PM
...Roger...'s Avatar
...Roger...
Yes you have a clutch switch in your car.You could have knocked the wire off the switch.Its on the clutch inside the car,two wire connector.If the switch went bad you can do a temporary wire around,just jumper the two wires.Put it back as soon as possible.
Roger
Old May 28, 2006 | 03:16 PM
brdd's Avatar
brdd
Thanks for the ideas fellows and keep 'em coming. I don't know what I would do without your advice. The battery is a brand new optima by the way.
Dan in Austin
Old May 28, 2006 | 04:24 PM
...Roger...
Dan in Austin
So what was the problem?
Old May 28, 2006 | 07:31 PM
brdd's Avatar
brdd
The problem is: you turn the key and no starter action. Lights radio gauges, yes; starter no. I doubt it is the starter. That's why I began asking about a switch or something in the interior since that is what I (BUBBA) took apart.
Old May 28, 2006 | 07:43 PM
...Roger...
did you check the safety switch on the clutch pedal ? did you check to see if you have 12 volts at the S terminal on the starter with the key in the start position and the clutch depressed?
Old May 28, 2006 | 10:43 PM
Richard Cooper's Avatar
Richard Cooper
Check your starter and make sure you are getting power to it when you turn the key to the run position.
Old May 29, 2006 | 06:57 PM
brdd's Avatar
brdd
As usual, it was something easy. Too embarrassed to divulge..... Thanks for putting me in the right direction, fellows....just send me the bill..........
Old May 29, 2006 | 07:43 PM
babbah's Avatar
babbah
Dont leave us in suspense, we want to know......
Old May 30, 2006 | 11:22 AM
brdd's Avatar
brdd
.........CHARGED UP THE NEW BATTERY.............
Old May 30, 2006 | 11:42 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
amazing
Remeber start with the easy solution first
BTDT
Tim
Old May 31, 2006 | 12:13 AM
babbah's Avatar
babbah
brdd,
I have an Optima red top in my BB and it sits for months on end, and it has never needed a charge...Is yours a red top or yellow top?
Do you keep it connected when it is in the gargae sitting? I have a battery cut off switch in mine and turn the battery load off when stored.....
To ideas on no go ignition?
