brake caliper assembly torque
Old May 28, 2006 | 09:00 PM
BigJim13 JR.'s Avatar
BigJim13 JR.
Default brake caliper assembly torque
HI
whats the torque on the bolts that hold the brake caliper assembly together?? and is there a difference between the front and back?
THANKS
Old May 28, 2006 | 09:12 PM
vabeachvette's Avatar
vabeachvette
caliper housing bolt
1974 and earlier ...................... 130 ft-lbs
1975 and on
front caliper ........................ 130 ft-lbs
rear caliper .......................... 60 ft-lbs
caliper mounting bolts .................... 70 ft-lbs
source: haynes repair manual
Old May 28, 2006 | 09:19 PM
BigJim13 JR.
Hi
thanks for the reply but you are saying that the bolts that hold teh 2 halves of the caliper together are 130 ft/lbs correct?
THANKS
Old May 28, 2006 | 09:22 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
That would be correct. I had to mount my calipers back on the car to be able to get the leverage necessary for 130 ft. lbs. Good luck.
Old May 28, 2006 | 09:27 PM
BigJim13 JR.
excellent
thanks guys!!
Old May 28, 2006 | 11:52 PM
chris73cpe's Avatar
chris73cpe
1975 and on
If your car is 74 or earlier, make sure your rear calipers were never replaced with newer ones before trying to crank them down to 130 ft-lbs...nothing worse than reassembling calipers with fresh new paint, new pistons, and o-ring seals then all of a sudden...CRACK
This is totally a guess, but I think the earlier rear calipers only had 1 bleeder based off the bleeding sequence info in my haynes manual
To brake caliper assembly torque
