tach wiring
Old May 28, 2006 | 10:22 PM
gator79's Avatar
gator79
Default tach wiring
I need the wire location for a 75 tach. I am converting to an electronic tach in my 71. there are 3 terminals, ground, 12 volts and signal. they are not marked. what terminal is for what wire? someone posted this earlier but I seached and can't find it. I want to test it before I install it.
thanks
Old May 28, 2006 | 10:30 PM
fast idle's Avatar
fast idle
don't have your exact answer,but on my 75 the tach's circuit board was fried and it was obvious because there was a burnt copper track in the board,just open it up and look at it. i fixed my circuit board with a small wire soldered to the contacts that were burnt.
Old Jul 14, 2006 | 09:25 PM
Rock'n Old's Avatar
Rock'n Old
Has anyone found the right wiring scheme for the three points?
Ignition, ground and signal. But which goes where?
Two upper and one down.
o -o - o - o - o - o - o - o - o -
Old Jul 14, 2006 | 09:37 PM
Kilroy1024's Avatar
Kilroy1024
1976 Tach PCB
Front and back view of PCB,
connector pins shown on bottom.
+ is 12V
- is ground
3rd one with the square wave is tach signal input.
If the board isn't the same, post a pic of your, and I'll mark it up.
Old Jul 14, 2006 | 09:45 PM
Rock'n Old's Avatar
Rock'n Old
ThanXalot Kilroy,
A pic tells more than a thousand words.
Exactly what I needed. Now I only have to tear the dash apart, I guess.
I love this Big Family o - o - o - o - o - o - o - o -
To tach wiring
