Fiberglass question on 72
Old May 29, 2006 | 07:15 AM
LS104's Avatar
LS104
Default Fiberglass question on 72
Doing a repair an need to know is a 72 Epoxy or Polyester?
Old May 31, 2006 | 11:12 PM
bondoboy's Avatar
bondoboy
A 72 should use regular fiberglass resin. It's about $38 a gallon. The later cars used smc. It costs a lot more.
Old Jun 1, 2006 | 09:40 AM
wombvette's Avatar
wombvette
Actually 72 is the first year the SMC type panels were introduced so there is a mix of types on them. You should be able to tell the difference, but if you cant, be safe and bond with the SMC stuff and finish with a good quality polyester filler.
To Fiberglass question on 72
