compression test results......
Old May 29, 2006 | 05:12 PM
curtisl0we's Avatar
curtisl0we
Navigator
Default compression test results......
all clynders are between 175- 180 psi.i'm wondering what the formula is to turn the results into a ratio?
Old May 29, 2006 | 05:22 PM
ajrothm's Avatar
ajrothm
Normally 175-180 psi is around 10-1...that is a very rough ball park figure.
Old May 29, 2006 | 07:48 PM
Simmo's Avatar
Simmo
The psi cranking pressures could be used to give an approximate dynamic compression and then with cam specs you could calculate approx static compression in theory.
Old May 29, 2006 | 08:09 PM
mandm1200's Avatar
mandm1200
Too many variables to have a formula for a calculation.
Old May 30, 2006 | 07:42 AM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
My 72 base 350 has 168-175 psi on compression.....I know it's not a 10 to 1 compression...runs on 87 octane in the FL heat with no knocking or pinging !!! Cranking compression is a variable of cam timing. This car has stock or close to stock cam specs.
To compression test results......
