TT2s Rims #
Old May 29, 2006 | 08:00 PM
badboyr6's Avatar
badboyr6
Default TT2s Rims #
hey guys, i'm getting the tt2s really soon, the 17x8 with 4 inch backspacing...would 9.5 fit?..anyways...i just need to know if the bolt pattern is correct...5x5 with 4inch backspacing? help please...
Old May 29, 2006 | 09:09 PM
wnjlt1's Avatar
wnjlt1
17x8 with 4" bs all around will work with no mods. 17x9.5 in the rear? some mods maybe required. bolt pattern needed is 5x4 3/4"
Old May 29, 2006 | 10:29 PM
Stumpdeisel's Avatar
Stumpdeisel
I have a pair of 17x9.5 with 5.5 BS. I have offset trailing arms, but will have to modify of remove the sway bar, and also get a shortened spring if I want to run them without spacers.
Also, I got mine used for about what two 17x8's cost, otherwise they're special order and cost almost double. Is is worth it to run a 275-295 tire under the wheel well is the question you have to ask yourself.
See this link for pics and more info...
http://forums.corvetteforum.com/show....php?t=1400839
SD
Old May 30, 2006 | 01:56 PM
badboyr6's Avatar
badboyr6
Default :)
thanks guys!
To TT2s Rims #
