hood relase broke
so i search the forum for that thread with the trick and go to work and gues what.... no little opening to stick the screwedriver in on my 68. but you know what i did find, a square panel held in place by 4 bolts where the access should be. any one else ever see this?
havent tried it yet , cable should be here by thursday. ill post some pics if anyone is interested
tim
The secret opening is on the drivers side right at the location of the hood catch. Look in and there is a plastic plug. remove it and you will need a long screwdriver, but I found that a piece if small pipe worked better. Slide it in until it stops. I had to hit it with some force to get the release to spring the hood open.
I tied a piece of wire to the release until I got a new cable. I don't know on the 68 but I would assume that the wiper door needs to be open to see it. Someone with an earlier C3 chime in.
I read all the threads, and prepared myself for a long PITA ordeal, and I got one. under the car, hanger wire in hand, I spend almost an hour trying to get my silly hood open, reeach up from drivers side..... nothing
Reach up from passenger side..... nothing
reach in from under the grill near the wiper door..... nothing
cursing, yelling .... screaming.... alll hope is lost .... despair
so im sitting next to him on the ground, crying in my beer and i happen to look up through the gills and what do i see ??????
The hood release mechanism, and a hole the exact size of a hanger wire. can it be this easy!?!?!?!?
so I reach in catch the hole and in 2 second flat the hood is open
fuel pump went in in 45 minutes ( had to go get some new hose).....
Im back in the saddle
cheers
tim
cheers
tim
I put in the new hood release cable and retainer, slid right in .... works like a charm
Thanks!!
geeeze thanks, now you tell me
Its Ok though I now know the secret
