Push rod length question
Old May 30, 2006 | 09:29 PM
Warhead's Avatar
Warhead
Default Push rod length question
I am going to use full rollers rather than the stock stamped rockers, 1.5 on both. Do I need to measure push rod length or will stock length be ok?
Old May 30, 2006 | 10:27 PM
Little Mouse's Avatar
Little Mouse
Stock length will work with 1.5 rollers.
Old May 31, 2006 | 12:12 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Go to your speed shop and purchase the $5 plastic tool that checks valve train geometry,..money and time well spent. It will tell you if you your push rods are ok, too short, or too long.
If the block has ever been decked, or heads milled, or you're using a head gasket that's thinner or thicker, etc, it's always best to check.
The little tool fits over the rocker stud (with rocker removed) and should touch the valve stem and push rod simultaneously as you lower it down the stud. If it's not touching both, you'll need a longer or shorter PR's.
Good luck!
Old May 31, 2006 | 08:29 AM
audiec's Avatar
audiec
I bought the push rod length tool (looks like a push rod but screws out to adjust for different lengths). Then adjusted until I passed the roller tip test.
Audie
Old May 31, 2006 | 07:22 PM
JPhil's Avatar
JPhil
I used stock length with my full rollers and the geometry worked out fine...Prob'ly shoulda checked 'em first, but I already had the p-rods and rockers and wanted to git 'er done.
John
To Push rod length question
