2 fer: dragging brake / steering issue
I did replace the master cylinder recently and am wondering if the main piston in that is not retracting. The pedal feels like it's all the way up.
I replaced the steering box, power cylinder, ram, idler, pitman and all the hoses. I adjusted the ram as per instructions.
The steering feels hard. It tracks good and I just had it aligned. Should I start with the steering box adjusting and work my way down, or what?
For the brakes, get the wheels off the ground and see how free they turn, if a caliper is dragging you will be able to hear it. Pull the wheels and check for runout, shouls be under .002 I think the spec is. That verified and done, adjust the parking brake to spec.
Let us know and good luck
