Oil pump doesn't clear main stud
Old Jun 3, 2006 | 04:39 PM
Maine Vette's Avatar
Maine Vette
Default Oil pump doesn't clear main stud
Well, the thread title probably says it all. I was doing some assembly on the motor today and discovered that the oil pump housing doesn't clear one of the rear main bearing cap studs.
I'm hesitant to start grinding away at the oil pump housing, but that's the direction I'm leaning in right now. What have others done? I'm sure I'm not the first to discover this problem.
I'm using the stock BB oil pump with ARP main studs.
Old Jun 3, 2006 | 05:05 PM
SIXFOOTER's Avatar
SIXFOOTER
wow, never seen that before. Looks like a lil grinding is the way to go
Old Jun 3, 2006 | 05:32 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Pretty common. You can get a 12 point nut that will help...or just do a little judicious grinding.
JIM
To Oil pump doesn't clear main stud
