pulling trans
Old Jun 3, 2006 | 05:12 PM
TFitz's Avatar
TFitz
Default pulling trans
Can the trans be pulled without the motor in a 70 ,if so what are the basic steps.the car is an automatic.Thanks
Old Jun 3, 2006 | 05:42 PM
joe73vette's Avatar
joe73vette
Jack car up so it is level
Remove front exhaust pipes
Support tranny on jack
Remove crossmember
Disconnect front of drive shaft
Disconnect shift cable, kickdown wire, speedometer cable and vacuum line
Remove splash guard
Remove bolts from motor
Lower tranny
Catch converter before it falls off
LOL Joe
Old Jun 3, 2006 | 07:28 PM
birdsmith's Avatar
birdsmith
Reassemble as follows-
Obtain four-speed and all attaching parts
Install four-speed transmission
Smile
To pulling trans
