fail-safe thermostat ?
Old Jun 4, 2006 | 09:58 AM
jshug's Avatar
jshug
Default fail-safe thermostat ?
Do you think there worth the extra bucks and do they work ?
Old Jun 4, 2006 | 10:03 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have always ran a failsafe and that is all I put in my vette. I would rather the thermostat fail in the open position than fail closed. So to me, yes they are worth the extra money.
Old Jun 4, 2006 | 10:31 AM
...Roger...'s Avatar
...Roger...
Never heard of it,how does it work? Is it open and then closes with heat---the warm up time must be extended.Thats not good.
Old Jun 4, 2006 | 10:36 AM
Fevre's Avatar
Fevre
It functions the same as a normal stat but if it fails it will go to the open position and stay there instead of failing in the closed position and staying closed
Old Jun 4, 2006 | 10:59 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
good piece of cheap insurance!
Old Jun 4, 2006 | 12:28 PM
CrossedFlags77's Avatar
CrossedFlags77
I put one in my car. It ended up failing during the winter so my car would never warm up because it was wide open. Atleast you know it works, I bought another.
Old Jun 4, 2006 | 12:45 PM
...Roger...
Thanks-- I'll have to check one out !
Old Jun 4, 2006 | 01:02 PM
Meh's Avatar
Meh
Even in the winter, if it fails closed, you're still stuck.
To fail-safe thermostat ?
