Installing Shifter Linkage? See Pic
Old Jun 4, 2006 | 04:40 PM
79vetter's Avatar
79vetter
Default Installing Shifter Linkage? See Pic
I'm finally getting around to reinstalling my stock BW T-10 shifter and linkage and am having a problem getting the linkages back onto the transmission studs. The linkage end has a rectangular opening that should go over a stud that protrudes out of the side of the tranny- however none of mine will fit (slip over) the studs. Am I missing something here?:
Old Jun 4, 2006 | 04:42 PM
Bob Onit's Avatar
Bob Onit
Thats as far as you can get it on the stud????????
Old Jun 4, 2006 | 06:38 PM
79vetter's Avatar
79vetter
Yep,,,It seems odd to me as well...Its been so long since I pulled them off that I don't remember how tight the fit was...guess I will keep trying.
Old Jun 4, 2006 | 09:08 PM
Bob Onit's Avatar
Bob Onit
I dont have a shifter handy to look at but it looks like the studs are incorrect...some were flat on both sides to accomidate the rectangular hole
Sorry, its been a long time since I mounted a shifter.
I'm sure somebody will pop in soon with the solution
Old Jun 4, 2006 | 09:16 PM
mensch53's Avatar
mensch53
It might be an odd angle or something, but it doesnt look to me like the linkage is at a right angle to the stud. It might be off just enough that it wont go through the hole.
Old Jun 4, 2006 | 09:26 PM
Edzred72's Avatar
Edzred72
I have a BW ST-10. Are the clevises the originals take off that trans? Are you sure your sliding the correct end of the clevis onto the trans....not the shifter linkage end?? If it's the reverse clevis it will only go on one way. With the interlock cable stud pointing tword the trans. (that's what mine was) If it came off...should go back on.
Good Luck
Eddie
To Installing Shifter Linkage? See Pic
