Huge problem - no solution
Old Jun 4, 2006 | 05:25 PM
BKbroiler's Avatar
BKbroiler
Default Huge problem - no solution
After trying to repair my driver's side door lock today I ended up with this: The door is closed and locked, and the door panel is installed. I can't move the lever to unlock the door while the door latch mechanism is bolted in place. (Thats what I was trying to correct.) The plastic guard piece is removed so I can see the lever. I can't loosen the 3 bolts on the latch with the door closed. Loosening them somehow allows the lock mechanism to be moved. Any ideas?
Old Jun 4, 2006 | 06:22 PM
sdonnelly's Avatar
sdonnelly
This might help. http://forums.corvetteforum.com/show...ht=door+locked
Old Jun 4, 2006 | 07:05 PM
BKbroiler's Avatar
BKbroiler
sdonnelly - Some of those tricks are worth a try. Thanks.
Old Jun 4, 2006 | 07:31 PM
...Roger...'s Avatar
...Roger...
Here is a longshot that has worked for me in the past.Take your engine oil dipstick or a piece of metal the same thickness and width and insert it through the small slot in your door handle and go down and hold the lock down while operating the inside door handle.It is the slot to the back of the car ,hold the dipstick up and down (put a mark on it 5 inches from the end)go down that mark and lift up and down until you get on top.Practice on the other door,this will also get you in the car without a key.I ground the end of mine like a fork.
Old Jun 4, 2006 | 08:16 PM
BKbroiler's Avatar
BKbroiler
dwncchs - There are no slots in my door handle. Thanks anyway.
I have to get my door panel off to try some of the other tricks.
Old Jun 4, 2006 | 10:28 PM
...Roger...
At the hinge pin---2 slots.Usually this happens when it is "not unlocking all the way".You can also put the key in and turn it to unlock (hard) and get someone else to pull on the inside lock ****(hard) at the same time while you try to open the door with the inside handle.
Old Jun 4, 2006 | 11:23 PM
BKbroiler's Avatar
BKbroiler
Thanks again guys. Ed T, your pics are always amazing, BUT, my real problem is that my lock lever will not move. It operates normally until the 3 slot head bolts that hold the door latch in place are tightened, then it jams. Today, I tightened the bolts thinking the lever was in the unlocked position, and closed the door. So the lever won't move. I tried that reaching down from the top. I'm trying to get the door panel off but the screw at the rear end of the door is buried with the door closed.
Old Jun 4, 2006 | 11:41 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Take the seat out and remove the door panel. Don't forget the one screw at the top corner, you have to remove some trim/molding. I had this problem once and even with the door panel off I couldn't get the lock to unlock. Eventually what I did is clamp some vice grips on the veritcal rod and jiggle the crap out of it and it opened.
Good lock
Old Jun 4, 2006 | 11:59 PM
SIXFOOTER's Avatar
SIXFOOTER
you have stock screws in there? sounds like the screw went in to far and jammed the mechanism.
Do it like Motorhead says, pull the set and then door panel, fix it right and don't break anything
Old Jun 6, 2006 | 07:38 AM
BKbroiler's Avatar
BKbroiler
Thanks for all the help.
Actually, sdonnelly's link with some pics was the most helpful in my case. I was able to push down on the flat tab to the left of the one shown. That allowed the door to open while still locked. I thought I was going to have to take a saws-all to it.
To Huge problem - no solution
