Brake proportioning valve checK??
Old Jun 4, 2006 | 06:00 PM
BIGJIM13's Avatar
BIGJIM13
Default Brake proportioning valve checK??
Is there a way to check the brake proportioning valve when it is off the car?
Old Jun 4, 2006 | 08:11 PM
Duke94's Avatar
Duke94
Do you mean checking for proper proportioning function? If so, the answer is no. In order to check it, you need pressure to both inlet ports, then a gage on the outlet port. If you want to see if the switch is closed (light on) just check continuity between the switch terminal and the valve body. It is a normally OPEN switch.
Old Jun 4, 2006 | 08:48 PM
BIGJIM13's Avatar
BIGJIM13
Yes - checking the function! off the car - how does one determine if it is bad?
Old Jun 5, 2006 | 08:52 AM
BIGJIM13's Avatar
BIGJIM13
So what goes bad in a proportioning valve - if you can spray brake cleaner in all the ports and it comes out other ports its clearly not clogged!
Old Jun 5, 2006 | 12:29 PM
Emeightch's Avatar
Emeightch
Or, buy a new one. We're talking about brakes here. Proportioning valves are not made to be serviceable and when in doubt, replace it for $85.
Old Jun 5, 2006 | 02:12 PM
Duke94's Avatar
Duke94
There is an atmospheric vent on the side of the end plug (rubber disc held in with a speed nut). If the vent leaks and salt water gets into the atmospheric chamber, the movable spool (which causes the valve to proportion) won't move. If this happens, you will get to much rear brake pressure and the rears will lock up before the fronts (not a good thing). As suggested by others, it would be prudent to just buy a new one.
Old Jun 5, 2006 | 07:38 PM
BIGJIM13's Avatar
BIGJIM13
Ok..one more question , I found another proportioning valve in the garage - I open them both up - on the one the little spring inside with the rubber seal stays pushed in - on the other it will not stay pushed in - which is right?
Old Jun 5, 2006 | 08:05 PM
VetteNut72's Avatar
VetteNut72
What year is your C3? I believe that proportioning valves started in 1974 (someone?). Prior to that, they were just a differential pressure switch that turns on the brake light if pressures differ between the front and rear systems. Maybe someone else knows for sure
Craig
Old Jun 5, 2006 | 08:28 PM
BIGJIM13's Avatar
BIGJIM13
thanks, a 74
Old Jun 6, 2006 | 03:41 PM
BIGJIM13's Avatar
BIGJIM13
Has anyone seen a pic of the inside of a proportioning valve - a cutaway view?
Old Jun 6, 2006 | 06:10 PM
Duke94's Avatar
Duke94
The rubber seal should move freely, the spring pushes it back against the face of the end plug. If it doesn't, it may be swollen from using the wrong type fluid. It's toast pitch it.
Old Jun 7, 2006 | 11:33 AM
BIGJIM13's Avatar
BIGJIM13
Thanks - will probably get a new one -
but just so I understand the function.... if the rubber seal moves freely, then it is always pushed up against the end plug, so the main hole is restricted and fluid flows through the two smaller holes! At what point does the rubber seal move to center? at full braking!
Old Jun 7, 2006 | 01:19 PM
Duke94's Avatar
Duke94
Maybe these pictures will help.
This is the proportioning spool.
This is the insides of the diff piston.
Basically, the rubber piece on the piston sits over the hole in the center of the endplug. During normal braking, the fluid goes through the 2 smaller holes on either side. When the pressure reaches a predetermined point (known as the "knee" point) the spool moves in the direction of the rubber and closes off flow to the brakes. In simplistic terms, the spool opens and closes "proportioning" the pressure to the rear brakes. On C3's, the rear pressure will be 43% less than the front pressure after the 500 psi "knee point" is reached. So if the front pressure is increased by 100 PSI, the rears are increased by only 43 PSI. I hope I didn't just confuse everbody.
Just a little more info. If the rubber disc in the side of the end plug leaks, water gets inside and corrodes the "spool". If the spool can't move, the valve will not proportion. It could also stick in closed position causing no rear brakes (this is rare).
Old Jun 7, 2006 | 03:31 PM
BIGJIM13's Avatar
BIGJIM13
Absolutely Great! Thanks for the reply - now I understand!
Well Done Duke 94
Old Jul 22, 2006 | 07:56 AM
mirrorfinishman's Avatar
mirrorfinishman
On a 69 vette; Is there any condition where the proportioning valve could cause sustained excess pressure at the rear brakes?
Old Jul 22, 2006 | 09:35 AM
Duke94's Avatar
Duke94
Actually, 69's did not have a proportioning valve. Just the warning switch. If your valve is mounted vertical on a bracket off the frame rail just below the M/C, you have the warning switch only. If it's mounted horizontal on the frame rail with 2 bolts, it HAS the proportioning valve. Hope this helps.
Old Jul 22, 2006 | 12:59 PM
mirrorfinishman
The car is a 69 and it is mounted vertical.
1- Is it basically just a 'flow diverter' with a pressure warning switch?
2- Since it is an original part that has never been replaced; could it possibly be faulty? Thus contributing to the rear brake caliper remaining pressurized (and heating up) after running at highway speeds.
To Brake proportioning valve checK??
Old Jul 22, 2006 | 01:12 PM
Duke94's Avatar
Duke94
1). Yes, it is just a Distribution block with a switch between the 2 systems (front & rear) to sense a failure in one of the systems.
2). There's not much to go wrong. 2 rubber o'rings on a brass piston and not much else. Are both rear brake dragging? If only one, then it can't be anything upstream of the rear brake line (the one that goes from the valve to the rear). If it's only one brake, sounds like the caliper may be bad?
Old Jul 22, 2006 | 04:24 PM
chris73cpe's Avatar
chris73cpe
Is it possible for the distribution block to go bad and cause the front brakes to pull to one side? My 73 just recently started pulling hard to the right when I hit the brakes and as far as I can tell the front brake pistons all move freely and there is no air in the lines. I know there isn't much to go wrong there, but I also noticed the brake light doesn't come on while bleeding, which I'd think should happen if all the brake fluid is going to 1 wheel.
Old Jul 22, 2006 | 05:28 PM
Duke94's Avatar
Duke94
The only thing in the distribution block that could cause pull is if you grossly overtightened one of the tubes on the valve and closed up the hole. In your case, the most likely cause of brake pull may be a restriction in one of the rubber hoses. Are they new? If not, you should replace them. The brake light should come on if the pressure at the rear brake is over 300 PSI higher than the front brake. When you are bleeding, keep pushing on the pedal and it should come on. If not, there could be something wrong electrically. To check if the light circuit works, pull the connector on the distribution block switch, and short the wire to ground. You may have to insert a jumper wire or probe to make a ground connection (key must be in RUN position). If the light comes on, then the circuit is OK.
