Speedpro Forged Pistons ???
Old Jun 5, 2006 | 12:14 PM
BG528's Avatar
BG528
Default Speedpro Forged Pistons ???
Hey guys,
Couple of the other forum members recommended forged pistions for my application. This is becoming a really expensive project, but I still want to do it right.
The engine started life as a GM Goodwrench 350.... cast aluminum pistons, and a cast Iron Crank, 76cc heads.
I bolted a 144 Blower to it, roller rockers, 200cc runner heads w/ 64cc chambers, 2.02/1.60 Intake Exhaust, 750 Double Pumper, HEI, MSD,
CR around 9.0:1.
The Cam I chose for the engine is from Lunati. Its part #501B1LUN and is a solid roller .566 lift, 242/249 Duration.
I also chose a set of verticle bar lifters #72402LUN
And Bump Stop #90001
The cam seems a little big, but I was told by Lunati that the blower will smooth it out and its rated from 2500-6500RPM which is perfect.
How are the speedpro forged pistons? The price "seems" reasonable, hows the quality. Also, I read somewhere that alot of the major piston manufacturers are having expansion rate problems with their forged pistions,... causing siezed engines... Whats the deal with Speedpro?
Barry
Old Jun 5, 2006 | 12:31 PM
sly vette's Avatar
sly vette
Sealed Power Co. has been around for along time. They carry the Speed Pro line. I put their cast pistons in my 350 and I don't expect any problems. I'm sure there are those out there that may disagree. I do wish I would have put in the forged though so that I could have gotten a more proper quench, I'm at .053. .040 is ideal...
Later,
Sly
Old Jun 5, 2006 | 12:38 PM
mvftw's Avatar
mvftw
I'm planning on a stock L82 rebuild. All the engine builders I've talked to recommend Forged...
Old Jun 5, 2006 | 12:39 PM
Ivan_the_Red's Avatar
Ivan_the_Red
Hey Barry,
I've used Speed Pro/Sealed Power pistons in more than a few motors and have had really good luck with them. There are better pistons out there, but for a street car they're affordable, popular, and will stand up to most street/strip use.
In addition you'll want to at least have the balancing of the motor checked
if you decide to use any other pistons.
For what its worth though, I would really really invest in a decent forged crankshaft along with some good rod-bolts at least, before you run that
crate motor to hard or introduce to much stress on those stock components.
Measure Twice, Cut Once
Jeff
Old Jun 5, 2006 | 03:57 PM
Little Mouse's Avatar
Little Mouse
With a blower use forged pistons.
Old Jun 5, 2006 | 10:41 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Mahle Power Pack Pistons. High silicon, Low expansion, Forged Pistons. No excessive clearances required. .003 recomended. About $500 with rings. Best of both worlds.
Old Jun 5, 2006 | 11:22 PM
BG528's Avatar
BG528
Thanks for the Input guys,
The price seems right for the "sealed power pistons." I should be able to get the engine bored .030 over for just under $400. I was talking to my son and thats what it cost him. As for the crank I would prefer to just have it cleaned. I am just 10 miles from "The Crank Shop" in Montgomery, NY. I hear he is one of the best around. I will speak with him sometime this week and see what he can do with the cast Iron crank I have. Maybe if its not too much $$ I will pick up some ARP Hardware.
Do I need any different rods or are mine Ok to use with my engine?
This is my first total rebuild so I will be relying on the help of all my good friends here on Corvette Forum for help. If anyone can give me any advice on clearancing of valvetrain to pistons, or setting the crank in the engine I would appreciate any and all advice.
Thanks again,
Barry
Old Jun 5, 2006 | 11:42 PM
Little Mouse
Its been awhile since I have had an engine bored I would think it
would be more like $20 a hole or $160.00. Forged pistons weigh
more then cast pistons you will need to get crank rods and pistons
rebalanced. If I were building a motor with a blower I would use a
forged crank and strong rods, but if you keep the motor at lower
rpms the cast crank may be ok. Use ARP rod bolts.
Old Jun 5, 2006 | 11:48 PM
BG528's Avatar
BG528
That would be nice.... Anyone know a good, reputable machine shop in the NY Tri-state area? If I can do better on the Quality and Price I would like to!
Barry
Old Jun 6, 2006 | 08:06 AM
63mako's Avatar
63mako
If you are taking the advice of forum members Forged bottom end on a forced induction or nitrous motor is common practice and makes sense. You only want to do this once. Forged, balanced rotating assemblies are available for a little over $1000. Pretty cheap insurance if you are buying pistons, rod bolts, disassembling, reasembing and rebalancing anyway. Good luck on your build
Old Jun 6, 2006 | 11:56 AM
Little Mouse
Buy the time you buy the forged pistons redo your rods
and have your stuff rebalanced you would be better off going
with a forged lower end.
Old Jun 6, 2006 | 12:13 PM
ajrothm's Avatar
ajrothm
A couple years ago I did a .040 350 with the Speed Pro forged pistons, coated skirts etc. It was a mild motor with worked 882 smog heads and a 292h comp cam. It didn't really make much power(****ty heads and cam) but we were spraying a 175hp shot through it with a rich tune up and mild timing and it never blew up or missed a lick. It was in a 73 Nova going 11.40s and we sprayed COUNTLESS bottles through it..
THey are good pistons..
Old Jun 6, 2006 | 12:16 PM
kdcollins's Avatar
kdcollins
I am currently running Speed Pro forged in my application. So far, no issues after about 1300 miles.
KC
Old Jun 6, 2006 | 02:06 PM
stingr69's Avatar
stingr69
Good pistons but a little heavy.
-Mark.
Old Jun 7, 2006 | 07:42 PM
jerrylee's Avatar
jerrylee
Barry
Were in New York are you?
Old Jun 7, 2006 | 09:44 PM
ferndog4's Avatar
ferndog4
-Mark.
http://store.summitracing.com/partde...5&autoview=sku
Hey Mark,
Speed Pro makes a lightweight version. I wasnt sure what the difference but for only a few dollars more I went with the "LW." Maybe less mass, faster revs? I am happy with so far 400 miles on engine.
To Speedpro Forged Pistons ???
