C3 Engine life ?
Old Jun 5, 2006 | 12:56 PM
Woody_in_MN's Avatar
Woody_in_MN
8th Gear
Default C3 Engine life ?
1) What is the life expectancy of the enignes used in the C3?
2) Is any engine considered more durable, reliable than another in the C3 lines?
- w
Old Jun 5, 2006 | 01:13 PM
SIXFOOTER's Avatar
SIXFOOTER
1. depends entirely on how its maintained, tuned and treated, a few hundred to upwards of 200,000
2. Not Necessarily, see 1 above
Old Jun 5, 2006 | 01:14 PM
mayberg's Avatar
mayberg
A buddy in town here had a '72 auto as a daily driver. He must have rolled the odometer at least two times. He recently put in a ZZ4 before he sold it.
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
1. Forever, if well maintained.
2. Probably not.
Old Jun 6, 2006 | 04:56 PM
Chilli's Avatar
Chilli
Since the VAST majority of C3s came with the tried and true 350, there's not much difference in durability/reliability. The L82 is probably a BIT more reliable than the LTI; it stands to reason that the higher the compression ratio, the more volatile an engine is (but since high compression creates more power, it's worth it). The only C3 engine I would call a piece of crap is the 1980 California-only 305. Most late 70s-early 80s 305s are both weak AND unreliable.
Old Jun 6, 2006 | 05:49 PM
stevekk's Avatar
stevekk
Regarding engine life, what does anbody think of the oil additives, for example Slick Fifty?? Are they worth it? Or just a waste of time?
Old Jun 6, 2006 | 06:00 PM
icanfixitforyou's Avatar
icanfixitforyou
The general consensus here is that slick fifty is nfg, most recommend using a good quality non synthetic racing oil and or adding oil additives to improve the lubricating qualities of the oil.
To C3 Engine life ?
