Master Cyl. Booster Question
Old Jun 5, 2006 | 06:24 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Master Cyl. Booster Question
Ok im cleaning up my firewall and sealing it because i have a bunch of little leaks. My question is if i remove the master cyl and booster do i have to bleed the brakes or can i just bench bleed master cyl.
Old Jun 5, 2006 | 06:55 PM
Duke94's Avatar
Duke94
Bench bleeding the M/C will work fine.
Old Jun 5, 2006 | 08:49 PM
Silver00V6Camaro
Old Jun 5, 2006 | 08:57 PM
BerniesVette's Avatar
BerniesVette
Are you just pulling the booster away from the firewall to seal it? If so, you don't have to disconnect the brake lines and do not have to bleed them. Maybe I'm missing something otherwise.
Bernie
To Master Cyl. Booster Question
