help from experienced - attacking the laundry list
Old Jun 7, 2006 | 05:16 PM
H2O-V's Avatar
H2O-V
Default help from experienced - attacking the laundry list
it has become apparent that my new-to-me '73 either has more miles on it, or was very poorly taken care of.. or it's just my luck!
after 10 months of daily driving, the laundry list of "need-to-do's" looks like this:
~it is currently burning thru a quart of oil every 400 miles.. plan for engine replacement.
~original suspension, and saging on driver's side.. plan on upgrading to poly, springs, shocks.
~wheel bearing noise.. replace when doing suspension.
~clutch throwout brg noise.. thought to replace with engine swap.
~suspect rear diff spindle bearing whining.. would like to replace when doing suspension.
~rear u-joint squeek.. again, while doing suspension.
sooo...
where should i start??
Old Jun 7, 2006 | 05:20 PM
Tonys96's Avatar
Tonys96
Louder exhaust
Old Jun 7, 2006 | 05:23 PM
Little Mouse's Avatar
Little Mouse
If you don't want to be calling a wrecker better start with the wheel
bearings and a new throwout bearing. Pull the trans resurface
or replace the flywheel and install a new clutch and throwout bearing.
the rear end stuff no telling what all will end up being replaced.
Old Jun 7, 2006 | 06:08 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
A quart of oil every 400 miles is a lot. My 71 Vega didn't burn much more Having said that, oil is cheap. I'd start with safety issues then work to the ones that could cause a big expense. In your laundry list, I'd probably start with the sagging suspension (steering kind of matters) and then go to the rear end issues as a broken u-joint can ruin your whole day. You probably want to do the motor first, but just add another quart.
Also, I guarantee that as you start working through these issues, the list will grow.
To help from experienced - attacking the laundry list
