'79 Shifter Adjustment
I don't have the official alignment tool so I used a small hex wrench to start inside of the notch. I have since made more of a flat object by cutting up a small flat putty knife piece.
The question is: how can you tell when the notch is aligned on all 3 levers? Should the tool go straight through the notch in all 3 in a fairly easy fashion?
I guess that you have to wiggle each lever until you feel the tool going in farther?
I was thinking about taking a hammer to the shifter bracket so that there would not be any gap between the levers on the control lever shaft. I have heard that over time the shifter bracket expands making shifting sloppy. I also considered putting a washer in between the levers to make it tigher.
Make a tool out of a scraper, cut the end 5/8" wide and 1 inch long. Bend this portion at a 35 degree angle. Chamfer the ends to 45 degrees.
Instead of trying to insert the tool into the notch while the shifter was mounted, I decided to take it out. I then aligned the gates perfectly as if I was going to install the alignment tool. I then painted a white line going all the way across all the levers on the back side of the shifter so that I could view the levers orientation to this line when installed. I installed lever - aligned all the levers onto the white line and then tightened down the nuts on the shifter rods.
Result:
Not too good. The shifter SOMETIMES feels good and other times feels terrible- meaning it won't go into a gear some of the time. Keep in mind this is all with the engine off and disconnected- (the car is not running presently). Sometimes I will go from Neutral to first and back 10 times and it feels smooth and then as soon as I go to 2nd and then back to first I can 't get it into gear or it is very difficult. It seems that 2nd and 4th feel better than 1st and 3rd. Reverse feels great.
I had also read on another post that the shifter bracket wears by expanding- creating small gaps between the levers riding on the shaft. I had small gaps so I used a press to ever so slightly narrow the gaps on the shifter bracket.
Any ideas out there?
