Help Justin !!!
Old Jun 8, 2006 | 09:16 AM
...Roger...'s Avatar
...Roger...
Default Help Justin !!!
QUESTION---Hey guys in a stock motor if you break a timing chain the pistons usually clears all the valves.In Justins motor with his cam would this be the case or is the clearance critical enough to tweak some valves.I am not familiar with his setup.I hate to beat a dead horse but I think a cyl. leakage test could be useful.
Old Jun 8, 2006 | 11:10 AM
...Roger...
Does anyone know the piston to valve clearance on his engine?
Old Jun 8, 2006 | 06:17 PM
...Roger...
Did everyone give up on Justin?The kid needs help!
Old Jun 8, 2006 | 08:50 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I had a timing gear break and ended up with broken valves, bent pushrods and 2 broken pistons.
Old Jun 8, 2006 | 09:00 PM
Maine Vette's Avatar
Maine Vette
Who's Justin? Not everyone may know him by his first name, not to mention his engine specs. You may get a better response if you call him by his screen name provide more info on his engine specs.
Old Jun 8, 2006 | 09:04 PM
Nacho_Libre's Avatar
Nacho_Libre
Old Jun 8, 2006 | 09:07 PM
...Roger...
Sorry its JustinD --- thread---No go on new engine parts
Old Jun 8, 2006 | 09:31 PM
Maine Vette
I believe that even in the stock setup the pistons would make contact with the valves if the timing chain broke while the engine was running. The cam would stop rotating pretty quick whereas the crank would take longer to stop, especially if the car was running in gear. Provided the crank makes one full revolution while the cam is stationary gaurantees valve contact somewhere.
Old Jun 8, 2006 | 09:34 PM
...Roger...
I was thinking it would do it with the wilder cams and not the mild ones.
Old Jun 8, 2006 | 09:37 PM
...Roger...
I was thinking he might have less piston to valve clearance than a stock cam and I dont know what pistons are in his engine.He has a Holley systamax whatever that is.
Old Jun 8, 2006 | 09:40 PM
Maine Vette
I just ran out to the garage and looked at my stock '71 LS-5 heads. The low side of the exhaust valve is only about 1/8" above the deck height. Based on that it wouldn't take much valve movement to cause a problem.
Old Jun 8, 2006 | 09:44 PM
...Roger...
I still think he might have slightly bent some valves.Thanks for checking your heads.
Maine Vette
Not to "monday morning quarter back", but it's always a good idea to verify piston to valve clearance when building a custom motor. You never know when someone may have provided an incorrect part. I've heard of people ordering cams and getting something totally different. Getting a cam with 3/8" lobe lift can be a big problem when you're only expecting 1/4".
Old Jun 8, 2006 | 09:46 PM
...Roger...
Yeh your right and what if in his kit they put in solid lifters? Ouch!
To Help Justin !!!
