I need to know if you have to remove the fan shroud to get the upper arm off. I,m in the middle of installing the VBP mono spring and upper arm kit. thanks for any help
I got them off on a 70 big block without removing the fan shroud. I did have to remove the bolts that mount them to the frame on the passenger side though. A few hits with a good size hammer/sledge knocked them out. They're splined like lug studs or the rear shock mounts...
