Vacuum Presure questions
Old Jun 9, 2006 | 04:03 PM
JustinD's Avatar
JustinD
Default Vacuum Presure questions
I have a 350 with a Holley systemax 2 kit on is and a Holley 750 double pumper. I'm getting about 11 pounds of vac at and idle. Does this sound low, or should I be fine? When I give it throttle it will drop a little then rise up. As shown in this video: http://24.118.233.41/vacgauge.mov What do you guys run for vac at idle and then about 2000 rpms?
Old Jun 9, 2006 | 04:28 PM
Gordonm's Avatar
Gordonm
First off it is vaccum not boost. Boost is positive pressure. 11 inches is not bad. I run at about 8 to 9 with a pretty radical cam. If your cam is mild you should be at around 14 to 16 inches depending on the condition of the engine.
Old Jun 9, 2006 | 04:38 PM
Gordonm's Avatar
Gordonm
Old Jun 9, 2006 | 05:11 PM
JustinD's Avatar
JustinD
Not to radical:
235°/240° duration at .050, .490/.490 in. lift, and 112° lobe separation
Old Jun 9, 2006 | 05:41 PM
Gordonm's Avatar
Gordonm
Where is your initial timing and are you running a vaccum advance. If you are are you running it to a ported or manifold vacuum. My vacuum went from 8.5 to 11 with my old cam and running a vacuum can to manifold vacuum. It was much more responsive. I was running 14 initial with another 12 degrees of vacuum for a toatl of 26 at idle with vacuum advance hooked up. It idled much cleaner and with better vacuum. My old cam was 248 @ .050 with a .525 lift. in a 350.
Old Jun 9, 2006 | 10:26 PM
JustinD's Avatar
JustinD
What is a vac can, just is like a backup device(stores the vacuum)? My vac advance is on the one that kicks in when you open the throttle. i am having problems with the car hesitating when you add throttle.
Old Jun 9, 2006 | 10:43 PM
...Roger...'s Avatar
...Roger...
He is talking about the vac diapram on dist.He likes his hooked up to full vac not ported like you have yours.How light are your cent. adv, springs---are they letting the weights come out at 1200rpm?In his the advance is full until you hit the gas and then it backs off.
Old Jun 9, 2006 | 10:45 PM
JustinD's Avatar
JustinD
Oh I see, I might change my vac advance once I get it tuned right.
Old Jun 9, 2006 | 10:47 PM
...Roger...
I bet your feeling better now.Keep on tweakin !!!
Old Jun 9, 2006 | 10:53 PM
JustinD's Avatar
JustinD
Ya feeling better that it runs, but had about enough tweakin.
To Vacuum Presure questions
