Gauge Problem on 81
Old Jun 9, 2006 | 10:20 PM
Willy899's Avatar
Willy899
8th Gear
Default Gauge Problem on 81
I am having problems with gauges on my 81. I don't show any oil pressure, Battery light is on and only reading 8 volts. I have tested the alternator and it shows 14 volts output. Gas gauge works ( I hope), temp gauge works and oil temperature works Ok. I have ordered a new circuit board but was wondering if anything else could cause this problem
Old Jun 14, 2006 | 07:21 PM
Willy899's Avatar
Willy899
8th Gear
Got a new circuit board today from ebay for $40.00. Seems to be good quality and installed easily. The only problem is there is a circuit for a clock and my car has no clock in the gauge cluster. Had to place electrical tape over this circuit to keep it from grounding out. The same thing had been done to the circuit already in the car. Took a picture with a digital camera to ensure everything went back together correctly. (had to refer to it). All gauges now seem to work perfect.
