Just out of curiosity, I googled this which should give you some hope!
But maybe wait til you hear from someone that has had some actual experience with a corvette rad...
One fairly common problem is a leaky petcock -- the small valve at the rear and base of the radiator (figure A) that allows the coolant to be drained when it's time for a change. If you've identified a leaky petcock, the repair is fairly easy to do yourself.
Drained my radiator and the whole plug fell out. Does it have to be welded back in (I can't weld) or can I use JB Weld or something similar?
That drain setup will never last anyway ... that's not a draincock or petcock ... that's simply some brass 90* & a pipe plug ... when you try to open that it puts torque in one direction and wants to break it off rad. You need to get a true auto draincock (like OE) that screws directly into a tapered-thread bung/hole in rad ... opening-closing torque distributed evenly & radially ... get one at auto parts store for $2-$3. JB Weld is good stuff but it probably won't work to fix broken out bung ... pull rad & have bung welded/brazed/soldered (dunno what your tank's made of ... you didn't show pic of rad). While it's out, may as well have rad inspected & cleaned real good.
You could always TRY JB Weld, Just clean it out good w/ alcohol and glue it bck in there. At best it would be a temporary fix (I can't think of anything that you could fix PERMANENTLY with JB Weld) though so you'll eventually have to pull the rad and have it re-soldered. That's not so bad though 'cuz pulling a C3 radiator is a far bigger PITA than soldering a little bung....
Bought a tap yesterday and tapped the hole in the bottom of the radiator (removed the front bumper crosspiece first for access) and threaded in the new draincock. It is in there quite snuggly but without sealant.
The guy at the parts store suggested teflon tape but that does not seem permanant enough for a pressurized system. Can I use some type of high temp ATV (like the kind we use on intake manifold bolts), or
JB Weld or fuel tank sealant or something else to seal the threads?
I do have excellent access to the area now that the crosspiece is out so I might be able to solder with the radiator in place if that is necessary.
I used teflon tape on mine and has held fine...you've got to figure a household hot water pressure has to be pretty high so it will work on a proper fitting plug in the car radiator....just my story
If its in there tight I would use the teflon tape
Drive it, get it hot (turn on the A/C if equipped and dog it up up some big hills) and check for leaks...
Keep an eye on the temp gauge and bring a few gallons of water with you... It might be fine.
Worth a shot, just dont cook the engine.
ps: you dont need a petcock to drain the coolant in the future... you can always yank the bottom hose so that shouldnt be an issue
The exact same thing happened to me a month ago. I tried the JB Weld and it held for a while. Then I went to unscrew the plug for the first time and it broke off. I wanted to tap it and put a new drain plug in but never could fine one that would fit the hole. All too small. Ended up taking the radiator out to take to a radiator shop to weld that little piece on. After I took out the radiator, I cleaned the fins the best I could. Still tons of crap left in there. I made the decision that since it was most likely the original radiator, it was probably due for a new one anyway. Ordered one from ecklers for $300. Car runs cooler now. However, that installation job was the biggest pita job I've ever undertaken. Looks like a relatively easy job but guess it wasn't for me. Good thing you didn't have to take the radiator out to fix.
If thats the case I would CERTAINLY replace it with a brand new quality radiator.
Sounds like you're short-cutting, and you may pay dearly for it in the future...for the relatively cheap price of a new rad, you'll kill numerous birds with one stone...IMO
