Drive shaft removal question
How hard is it to get the driveshaft out? It looks like it will be hard to get the yoke out of the transmission without dropping the rearend out of the way.
I have a Turbo 350 and the car is a rag top if that matters.
Any advice would be appreciated.
Thank you.
safely jack up the rear of the car on stands so the rear tires are off the gound and put the tranny in "N"
Pop the straps off the front u-joints Pry the yoke forward into the tranny tail housing just enough to lower the front of the drive shaft down.
remove the rear straps and pull it out.
Just like the half shafts it's best to use a H-Press to pop the u-joints in and out. just support the ends so nothing gets bent if they are really rusted in or something.
leaving the yoke in has less chance of any fluid dripping out...
I have a vibration issue that tempted me to look at the drivetrain. I have play in both u-joints and the tail shaft of the transmission.
The driveshaft doesnt have retaining bolts/straps on the transmission end (only the pinion u-joint has straps) so the only way I could remove that end is to try and press out the u-joint while its still in the car...
The pinion end of the driveshaft is pretty much captured by the rear end .. drivetrain.. support structure.. stuff... (this is my first IRS so I'm not sure what to call things).
I'm just not seeing where I can find room to unhook the pinion u-joint and slide the driveshaft back far enough to slide out the yoke from the transmission.
This is not the original transmission or driveshaft. I'm afraid that it was put in as a unit. I can't begin to tell you how many things were hacked up on this car when I got it. At this point i'm almost suprized the u-joints were not welded in...
We unbolted the exhaust and two tranny tail shaft bolts. maybe the motor to firewall ground strap. Then we took out each of the lower motor mount fore and aft bolts. Floor jack under the tranny with the wheels able to roll forward. We were then able to move the motor about 1.5 - 2 inches forward enough so the tranny tail shaft yoke and driveline came out.
we didn't unhook anything else. air cleaner was off. The wires, fuel, and rubber hoses all had enough length
Sounds like a good reason to do a gear change and just fix it when the rear suspension is out...
Thanks for the help!
