you will have to make a plate to cover the hole, use a gasket. Follow the hose back to the TFS, it can be removed. The other side of the TVS should be source vacume, remove that line and cap its source.
u'll get a little bit of power out of it nothing really noticeable but it just holds ur engine back and u really dont need it. if u have one on ur car take that off including ur smog pump unless u live in a state where u have to get inspections.
The EGR is actually a good device, it uses very little hp and does reburn some of the emisions. I am keeping mine and just cleaning it up and making it work right
I remover the pump could not see any use for it, but the egr might be helping out the air I think I will clean it up and keep it for a while....
In calif 74 is the last year that no smog is requires.
From: San Diego - Deep Within The State of CONFUSION!
yes it is, and EGR also cools combustion chamber temp causing less susceptibilty to ping. Why would you want to defeat that?
