Spring de-arching or longer spring bolts - any ideas
Old Jun 12, 2006 | 10:10 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Default Spring de-arching or longer spring bolts - any ideas
There has been a lot of talk about shortening the rear spring for longer bolts in order to run wider wheels. Is there a down side to de-arching the spring, and using shorter bolts to allow the spring to extend into the rear wheel? I have 18” wheels so letting the spring extend into the wheel is not a problem. I am not sure if it can be done with 15” wheels maybe someone can check.
I had an extra leaf added to my spring in order to increase the spring rate, than I had the spring de-arched so it would extend into the wheel this allowed me to use shorter spring bolts. I spoke with the owner of the spring shop that done the work about the effects of de-arching the spring. He indicated that it would have little or no effect on spring rate. What are your thoughts on this?
Neal
Old Jun 13, 2006 | 09:45 AM
75 Hot One's Avatar
75 Hot One
I've got a similar set-up. The arch does not enter into the formula for calculating the spring rate so I assume there's no effect.
Old Jun 13, 2006 | 07:55 PM
chevymans 77
After looking at RedBad1979's pics I don't think there is room with 15" wheels to allow the spring to extend into the wheel.
Old Jun 13, 2006 | 08:05 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Unless the spring is completely worn and tired so that it's flat with the car's weight on it there is no way you can have the spring extend into a 15" rim.
My spring is aftermarket or re-arched (previous owner installed it) so I needed the long bolts to get the ride height acceptable and the half shafts straight ...
I'm trying to find one of my old photos that show the same spring with the stock 6" bolts and post it... look at the half shaft angle with the car's weight on the spring.... it's a miracle that the U-joints didn't fail....
Old Jun 13, 2006 | 08:14 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
OK... found it:
This photo was taken with the car's weight on the spring and the stock 6" bolts. The suspension had time (and a few miles) to settle.... the ride height was at 31 or so inches.... but the spring end wasn't close to the tire
Old Jun 14, 2006 | 07:45 AM
sxr6's Avatar
sxr6
My 69 rides high in the rear too! With angles like RedBad79.
How much weight from my SB to BB switch will be transfered to the rear? Enough to settle it down a couple inches? I doubt it!
I was also thinking of removing the top couple of short leafs!
That should soften the ride & allow the rear to settle down a little more!
Comments
Old Jun 14, 2006 | 01:50 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Comments
I would not remove leafs from the spring. With longer bolts your ride height and the half shaft angle will be fine
Old Jun 14, 2006 | 01:56 PM
xcelciador's Avatar
xcelciador
You'll be fine if you remove a few leafs. Id rather do this than have those rediculously long bolts.
Chevy mans- what rear spring do you have? Repro's are usually much stiffer than stock.
Old Jun 14, 2006 | 08:45 PM
chevymans 77
the stock rear leaf plus I had one added.
Old Jun 14, 2006 | 08:50 PM
norvalwilhelm's Avatar
norvalwilhelm
15 in won't but I did a 17 inch this past winter that did allow the spring to pass inside the wheel. You would be fine with the 18 inch rims.
I too had a spring dearched once to lower the car without resorting to longer bolts
Old Jun 14, 2006 | 10:37 PM
xcelciador's Avatar
xcelciador
Roughly around 155-160 rate. I don't see how you would have any height problems.
Old Jun 14, 2006 | 10:48 PM
chevymans 77
I had a leaf added a while back; this raised the ride height so I than installed longer bolts to lower the rear. Latter I than installed Z06 wheels and set them in as far as possible, this created an interference fit between the wheel and spring. Also I wanted a lower than normal stance for my car so rather than cut the spring I opted to de-arch the spring and allow it to extend into the wheel.
To Spring de-arching or longer spring bolts - any ideas
