Is this motor "streetable"?
1970 LS6 454ci Chevrolet engine, roller motor, approximately 500hp, 635 lift roller cam, roller rockers, ported closed-chambered 427 Corvette heads, rebuilt transmission w/shift kit and 3000 stall converter, 10 bolt rear with 3:90 gears, 3 inch exhaust Ultraflow mufflers
Thanks,
nacho
Thanks,
nacho
I would get lots of pics and faxes of paper work on the engine/trans if this is an ebay special. BE WARE ebay cars...
The 1970 LS6 is 11.25 to 1 stock. It did come with closed chamber heads so the 427 corvette heads are probably the same as the stock heads unless they have been milled. But you could run it on pump gas with the aluminum heads and the right cam selection. You could always drop the compression a little with an aluminum head with a larger combustion chamber. A custom grind cam should be available to help resolve your problem and compliment the change in compression, retarding the timing a little will help a lot. There are a lot of guys out there running there late 60's High performance, Iron head 427 cars on premium gas by backing down the timing. It will cost you HP but you can drive it.
Do your research on your engine combos but 11-1 on an LS6 will not get you very far for long.
Calling the engine an LS-6 means very little. It's not an LS-6. Roller cam is a dead give away. Who knows what else was changed. If it's only 500hp, it may be tame enough for the street. In my opinion, what makes an engine unstreetable is when it will not run somooth enough at 2500-3500 rpms. In other words, you got to keep it running at higher rpms. An 800hp Nascar engine is streetable if you want to drive it at 5000 rpms minimum.
If you have a radical enough motor that requires high octane, go buy racing fuel of around 108 or 112 octane and put 5 gallons in each time you fill the tank with premium pump gas. THAT will boost your octane level enough to keep the motor happy. Those boosters and additices they sell are nothing more than BS and the only people that benefit from them are the people selling, them not the people using them.
Although ... part of the reason is due to aluminum heads AND closer attention to how efficient the heads' coolant passages are. Some of the newest designs include direct injection which also helps chamber cooling ... piston crown shape (in conjunction w/ above-referenced chamber design) also aids chamber cooling. Been looking at newest 2 liter turbo motor for saturn roadster ... marvelous.
Well when you're mixing it with a 20+ gallon tank of gas it doesn't do jack, obviously. However, I accidentally put 87 in my bike once and noticed it was missing some power. Put a bottle of octane booster in it and it perked right back up. When you're only mixing it with 4 gallons of gas it can help.
Thanks,
nacho
Thanks,
nacho
(Quote) This post is "aimed" at the many up here that follow HP/Torque numbers with respect to "stock" and "stock appearing" units. The unit was first tested with our carb and headers and came off the dyno with 510 HP @ 5700 RPM and 500 Ft.Lbs. Torque @ 3900 RPM. This was with open headers. We were happy with those results. Using the customers carb and our headers it did 495 HP/500 Torque, same RPM's.
After installing his cast iron factory exhaust manifolds and leaving his carb in place, our final "as-delivered" numbers were 464 HP @ 5800 RPM and 484 Ft.Lbs. @ 4200 RPM. The exhaust's here are the "restrictor".
What we've concluded from this test on this particular unit is the fact that the stock "square-port" intake, #3963569, IS capable of producing past the 500 HP number, unlike the recent LS-5 "oval-port" test where the "open-headers" made absolutely no HP difference. We estimate we could possibly get 550 HP through this particular intake. We have to make certain we don't have a vacuum issue for accessories! A slightly larger cam along with headers would have made a significant HP increase.
This is a "pump-gas" unit that runs fine on 93. The specs are 10:1 C.R., 238/248 @ .050" x .550"/.570" x 112L/S. This is a solid lifter unit with a set of "Probe" pistons, a +.250 long rod, and stock valve sizes with .375" stems.
The #291 heads, in at 99 cc's did receive a decent amount of "bowl/runner" work, but NOT a "full-port". We felt that extensive cylinder head work would be wasted using the stock intake setup! It's topped off with a set Comp Cams #1320 rockers and will end up with the stock valve covers in place.
It was destined to be at Englishtown for the "Fast" race today but obviously didn't make it on time. It posed no problem however. It's headed into a "numbers matching" 1970 Chevelle.
Below is a shot as it was delivered. The valve covers/breathers are for test only! Thanks, Gary in N.Y.
P.S. When you are ABSOLUTELY "locked-in" to stock appearances you will find that the HP numbers are difficult to deliver. This unit is in "contrast" to the 396 pump-gas one a few months back, using the "Winters" (open-chamber) heads, 10.5:1 C.R., a step or two up on the solid lifter cam, and an old "Torker" intake, that was delivered with over 500HP on 93! That was with a "Holley" and open headers. (End quote)
Hans
This is the same product and according the the packaging, you can go 16 points higher if you want to....just don't think anyone here will need to. It has a chart on the bottle that tells you how much to add per gallon for octane boosts from 2 points to 16. Because of it's poisonous nature, you need to be careful using it, but it does work. I've been adding enough to get 93 pump gas up to about 98 and have been running 36 degrees advance on 10.8/1 CR with iron heads without a problem. That may be more than I need, but I like the valve seat lubrication too and I'm running the old double humps with larger valves.
