replacing door frames on rear storage compartments
Anyone replace the door frames and main frame on the 2-door style
rear storage compartments? How difficult is it?
The door frame handle broke on mine. Plus the door frame and main
frame have a crack. I purchased a complete assembly from Zip which is
made by DeWitts. It looks and fits well, except the carpet is a bit thinner
and the doors are made of wood instead of plastic. So I would prefer
to rebuild the original assembly and install it.
Re: replacing door frames on rear storage compartments (mark79,80)
you can buy just the frames from the same company Dewitts for about $20,got mine thru The Last Detail. you just break off the old frames(no way will they come off in one piece) and then sand down the 4 sides so that the replacements will just fit over. the new frames are held on by screws,which you will have to purchase. i used a belt sander to speed up the process and also used it on the top of the doors to get off little tufts of carpet that didn't pull off.
