how do you install freeze plugs?
Old Jun 15, 2006 | 11:23 PM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
Default how do you install freeze plugs?
how do you install the small 1/2 freeze plugs in the front of the engine on a 350? the middle hole seems tooooooooo small and the two side hole seem tooooooo big and the freeze plugs just slide in with a gap all the way around them. can i just tap the holes and put pipe plugs in them?
Old Jun 16, 2006 | 10:00 AM
Schwee's Avatar
Schwee
Get the right size freeze plugs. Should be a tight fit that you can tap in. Freeze Plugs come in all sizes, metric and Amreican.
Old Jun 16, 2006 | 11:03 AM
LIQUIDDRAGON
i was using the freeze plugs that came with my small block 350 rebuild kit. my original 350 has three little 1/2" plugs in the front and this new GMPP block has all the same holes but on the front the middle hole is a little smaller than on my original block and the two side hole are bigger. i will run by the auto parts store here in a little bit when they are open and see if i can get the right plugs. thanks
To how do you install freeze plugs?
