C3 door replacemnet
Old Jun 16, 2006 | 03:18 PM
rlofaro's Avatar
rlofaro
Cruising
Default C3 door replacemnet
Hi All, On my 73 vette, I have 78 doors that someone put on years ago.
The door open handle is on the top right. I would like to put the correct doors on it with the door open handle running off the armrest.
My question is, a friend of mine has a pair of 75 doors, will these be a direct fit on the 73?
Thanks Richie
Old Jun 16, 2006 | 03:33 PM
vettfixr's Avatar
vettfixr
Corvette America lists the same doorpanel for 70 - 76 so I think your OK. If you want exact doors for it you could always give a corvette salvage yard a call.
Old Jun 16, 2006 | 03:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rlofaro
...My question is, a friend of mine has a pair of 75 doors, will these be a direct fit on the 73?
Thanks Richie
Yes and no. Coupe or convertible?
73 and 75 doors are pretty much the same. The 75s ought to fit your 73. The real work is adjusting the fit after you've installed them.
Old Jun 16, 2006 | 04:01 PM
stingrai's Avatar
stingrai
They will fit, as indicated, you will just have to align them properly
Old Jun 19, 2006 | 07:38 AM
rlofaro's Avatar
rlofaro
Cruising
Thank you all for your input. You have been very helpful.
Regards Richie
To C3 door replacemnet
