Problem with Flexalite fans
Old Jun 18, 2006 | 01:53 PM
LFZ's Avatar
LFZ
Default Problem with Flexalite fans
When the engine reaches 180 degrees, and the fans kick on, the fuse on the fans blows. So i switch fuses, and it does the same thing? Any ideas?? No wires seem loose, and i have had these fans on and working fine for over a year??
Old Jun 18, 2006 | 01:59 PM
BerniesVette's Avatar
BerniesVette
Have you added any other devices that is now pulling more amps and overloading the circuit? Also, have you put the fans on separate relays?
Bernie
Old Jun 18, 2006 | 02:50 PM
LFZ's Avatar
LFZ
no other devices have been added..i have a 100amp alternator. I just installed the fans as per instructions. I have had the fans working fine for alittle over a year now...it all of a sudden happened...it keeps blowing fuses.
Old Jun 18, 2006 | 03:18 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Welcome to elecltical trouble shooting.
Unplug/disconnect 1 fan at a time to see which electric fan mtr may have a short. Now u can also connect a multimeter in series with each fan to measure current but if the fuse blows immediatly then u won't get a chance to read the meter. That meter would also need to have nearly a 30 amp range as most hand helds are only 10 amp. Now electritions use a clamp on ampmeter (sold at HomeDepot etc. but not cheap - rent/borrow) that can handle hi amps. Just read the instructions, test with the headlights/batt cable for DC, toaster/microwave for ac currents (well just to practice).
BTW u know what i think of electrics fan Red but hope this helps to keep that nice shark stay on the road.
Good luck. cardo0
Old Jun 18, 2006 | 03:30 PM
LFZ's Avatar
LFZ
Cardo, the fuse blows immediately...I know...is it that one of the fan motors has a short, or could it be possible that one of the motors is blown?? (which i hope not)
Old Jun 18, 2006 | 04:24 PM
BerniesVette
Either one of the fans has a short, or you have a short in your wiring. As CardoO said, unplug one fan at a time to see if it is in the fan. If it still does it, check your wiring.
Bernie
Old Jun 18, 2006 | 07:01 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Be sure to check the ground(s) on the fans
Old Jun 18, 2006 | 10:11 PM
LFZ's Avatar
LFZ
thanks for the input guys...I'll check all of the above suggestions
To Problem with Flexalite fans
