Half-Shaft/U-Joint Help Needed
Old Jun 18, 2006 | 05:07 PM
rondo73's Avatar
rondo73
Default Half-Shaft/U-Joint Help Needed
Started rebuilding my half shafts this weekend. Tapped out the old u-joint caps with a hammer and socket . . . no problems. Tapped the new caps into the spindle flange end, installed the clips . . no problems. When I tried to install the u-joint/flange to the half shaft, I ran into a problem. I can't get the last cap to press in for enough to install the last clip. What am I doing wrong?
One thing I forgot to mention, after I had problems with the first half-shaft, I moved on to the other half-shaft . . . same problem occurred, couldn't get the last clip in!
Old Jun 18, 2006 | 05:19 PM
...Roger...'s Avatar
...Roger...
If you didnt loose one of the needles inside then you might have to bolt the flange to the axle flange so it will flatten or be straight.You probably bent it together a little bit
Old Jun 18, 2006 | 05:20 PM
...Roger...
they make a tool for that which is basically the spindle flange but heavier--I usually lay the flange over the 1/2 shaft and hit it and spread it before trying to put caps in.
Old Jun 18, 2006 | 05:29 PM
StingrayDK's Avatar
StingrayDK
Sounds like you might have slightly bended the "ears" on your halfshaft, its very easy done.
You could try to gently "wack" it straight with a piece of wood and a hammer, or trimming the locking clips thinner.
If none of it works there might be a new halfshaft in your future
Old Jun 18, 2006 | 06:25 PM
Vettkeeper's Avatar
Vettkeeper
What I have found when pressing U-joint caps into drive shafts, half shafts or flange ends is when you use a vise and socket to press the caps on; this process can close the gap (bend the ends) between the ends of the shafts where the clip needs to be. Once you have pressed the caps into the shaft using a vise and reasonable pressure (5-1/2 vice without a cheater bar) does not work. Stop!! Find a 4’’ piece of 2x4 and lay it on a hard surface. Take the end that needs to be recessed to install the clip lay it so you can hit it with a socket and hammer on the 2x4 and hit it until it just gets the point where you can install the clip. Repeat the process for the other clips. It is important you make sure all the needle bearing are in place before starting any part of the installation.
Old Jun 18, 2006 | 07:07 PM
77 vette's Avatar
77 vette
That's how I did it. I also lightly sanded the rust and crud out of the shafts and the clip slots, I used a little oil to help it in/seat.
To Half-Shaft/U-Joint Help Needed
