Oil pressure issue
The pump has <100 miles on it - is the motor freshly rebuilt , or did you just replace the pump for whatever reason , and now have a problem that didn't exist prior to the new pump?
Oil pressure gauge (mechanical) was gunked up (would only go to 35 psi max), so I wasn't aware of this problem, although it was probably there all the while. I'm thinking the pick-up may be bent (if not welded), and sucking air.
), I still see problems pop up that are new to me. I am not a noobie at this, but I am always learning....
Once engine and oil are @ normal operating temps , 15 psi idle is ok, 35 @ 2k is ok , but once rpm's go up, oil pressure doesn't climb upward with increases in rpm. This would indicate an obstruction to flow , since the gauge shoots up , then falls back and wavers. Oil can't freely flow through the filter , but the filter is flowing enough to keep the bypass closed. As an additional note here , it isn't oil pressure that lubricates and cools metal , it's the presence of a steady flow of oil that accomplishes that. As long as pressure is sufficient to keep a steady non-aerated flow of oil moving , it will carry the heat away. If it were pressure that did this , machine tools would use a fire hose to lubricate the metal being machined on them. ( My father was a tool & die maker , I got to sweep up the chips in my tender years. Guess what kinds of conversations we had , aside from my occasional griping about being a janitor, with the expected parental response to those remarks
)Since you didn't state that the gauge was giving you these kind of readings prior to the rebuild , and since the gauge was all gunked up , this would support the premise that the cold oil was bypassing the filter and reaching the gauge. And , gunked up or not , cold oil was giving you a 60 lb. reading , so that shows that the gauge was ( is ) capable of reading higher than 35 , assuming that oil flow could reach it. More support for the hypothesis.
Oil pressure is primarily a function of bearing clearance , and rod side clearance on the rod journals. Hot oil differences in viscosity will have small practical effect on oil pressure. The reverse corollary to this is building a motor with large clearances to keep the motor " loose & free-revving " , and using a 60 wgt. oil to " float the rods and crank on a thick film of oil ". Dream on , and keep those flashbacks comin'. The idea that a film of oil will keep will keep a rod end from wanting to continue in the direction it was travelling @ high velocity when the crank stops moving in the same direction and starts to reverse direction to push the rod in the next stroke direction is absurd.
For all the above reasons , that's why my first suspect is the filter being clogged. However , having said all this , if you have already changed the oil & filter , or if the problem remains after doing so , then I would move on to the following checks. ( It's also a good idea to use a magnetic drain plug , if you aren't already using one , btw. )
Verify the pressure readings using another gauge ( owned , begged , borrowed , but not stolen ) .
Check oil pickup distance to the bottom of the pan , and check it for parallel axis to the bottom of the pan. Also check the pickup screen for clogged debris in the mesh. I use a 1/4" pickup to pan clearance distance.
Also check , as you mentioned , that the pickup tube has been brazed to the pump body , once it's correct alignment position has been verified. Remember to remove the relief spring before brazing , or the spring will be junk. If the pickup tube has been brazed , and you aren't absolutely certain that the spring was removed during the brazing process , replace the spring as a prudent precaution. A spring that has been overheated during brazing will also cause intermittent erratic pressures before it fails completely.
Check that the oil pump body has been correctly located on the dowels it aligns to , and that there aren't any gaps between the pump and journal mating surfaces. Also check that the pump bolt has been torqued to spec ( 60 lbs. , IIRC ).
Last practical culprit could be excessive end play between the pump gears and pump cover, but I think this very unlikely. End play should be @ .002 to .0025.
Hope this will be of benefit to you. Sounds like you've got a strong powerplant that'll put a smile on your lips and a song in your heart.
David
( note my remarks in middle of paragraph 2 of my original post ). I'd be very surprised if your findings didn't solve the problem. I wish that I could say in these times that I was surprised that it was a defective new product. ( You would think that to be fair the price would be the same as it would sell for in China. )This is exactly the kind of thing that prompted me to construct a new personal consumer mantra. Buy American , if you can find anything American that you can actually afford to buy. $$ =
Is that the reason they're referred to as being " timeless classics " ?
