Distributor Oil Leak ????
Old Jun 19, 2006 | 10:39 AM
secrt0007agt's Avatar
secrt0007agt
St. Jude Donor '15
Default Distributor Oil Leak ????
I was at a NCCC show this past weekend & a judge/inspector told me I had a oil leak coming from the distributor. He showed me some oil collecting near the shaft base and said it was a bad bearing or sleeve that was causing the leak. Has anyone dealt with this issue & can give me some pointers? Thanks--82 Crossfire.
Old Jun 19, 2006 | 02:48 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Have you replaced the gasket that fits between the base of the distributor and the intake manifold? Or is the leak coming from somewhere else?
Old Jun 19, 2006 | 03:24 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Just went through this with mine. The leak was at the elbow for the oil pressure sending unit and sprayed oil on the base of the distributor. I changed the distributor gasket, put RTV on both sides (bad idea by the way) and removed and replaced at least 5 times. Finally stuck my had back there with the engine running to find the leak was somewhere else.
Old Jun 21, 2006 | 12:09 PM
secrt0007agt
St. Jude Donor '15
I have gone in there with some brake cleaner & cleaned the area around the distributor up. Later today I will run it to get an exact location of the leak--I hope.
Old Jun 21, 2006 | 09:50 PM
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
I have a recuring leak in that area, after making sure it was not comming from the oil pressure tube I decided to verify the intake seal to block,,, after pulling the intake twice and re-sealing with new seals etc etc, I'm still getting a little leak from something ???,, and its going to stay that way.. ,,, Maybe distributer ?? its possible,, but still looking for clues....
Old Jun 21, 2006 | 10:33 PM
secrt0007agt
St. Jude Donor '15
I cleaned around the alternator & drove it a little while, but I can not detect any leaks so far. It can't be too much, so I will keep monitoring it & post a final analysis--if any is found. Thanks
To Distributor Oil Leak ????
