what prevents me from
Old Jun 19, 2006 | 08:57 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default what prevents me from
Running a -10 braided stainless steel hose to the gas tank?
My fuel pump requires a -10 line, as well as my HP requirements....
Old Jun 19, 2006 | 09:00 PM
Greg's Avatar
Greg
Just another Corvette guy
Don't let anything but fear and common sense hold you back!
Old Jun 20, 2006 | 12:10 AM
Guru_4_hire
Cruise-In V Veteran
Dont worry I wont
Old Jun 20, 2006 | 12:16 AM
rcread's Avatar
rcread
Braided fuel lines can leave your garage smelling like fuel. If that doesn't bother you, go for it.
Old Jun 20, 2006 | 01:16 AM
Victor's Avatar
Victor
I have a fuel pump that also has a -10 fitting on its inlet. However, since I'm using the stock sending unit on my '79, I didn't see the point in running -10 line. The diamater of the large sending unit tube is slightly smaller than the diameter of a -6 line. Being the novice mechanic that I am, I would assume that since the diameter of the tube from the sending unit is smaller than a -6 line, fuel won't flow any faster through a -10 line than it would through a -6 line.
So what I'm saying is you probably are going to need to upgrade your sending unit somehow so that the tube drawing from the tank is no smaller than a -10 line. I think I would install a -10 bulkhead into the tank and draw from that if I needed that much fuel.
Since I'm running a fairly average 465 hp 383, I didn't think I would need enough fuel to warrant running a -10 line. I ran -6 line and used a fitting to reduce the -10 fitting on the pump to a -6. Somebody please let me know if I'm completely wrong with my logic and I messed this up!
Old Jun 20, 2006 | 01:35 AM
Guru_4_hire
Cruise-In V Veteran
I can probably modify the sending unit
Old Jun 20, 2006 | 03:51 PM
davidm_comp's Avatar
davidm_comp
Why would braided fuel lines make your garage smell like gas, as compared to steel lines with rubber lines from the tank? I cannot believe that they would leak gas, unless you did not put the connections on correctly.
Old Jun 20, 2006 | 06:50 PM
MartyW's Avatar
MartyW
I as wondering the exact same thing.
Old Jun 20, 2006 | 07:25 PM
68 NJConv 454's Avatar
68 NJConv 454
Me too, besides gas would actually improve the smell of my garage/tent/corvette restoration center.
Victor, what brand hose did you use? how did you attach it to the sending unit? and did you run a return line?
If your hp requirements need a -10 line then you might as well put a bulkhead in the lowest part of the tank with a -10 fitting. You've got to be running a high power electric fuel pump or high perf mechanical pump with hp requirement like that so I see no point in running a -10 line if you initially have to squeeze the fuel out of a sending unit that smaller than -6. There would be no benefit of the -10 line then.
If -10 is needed then do -10 all around.
good luck guru
Old Jun 20, 2006 | 07:37 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I need new fuel lines, too
As a temporary solution (well, it's been like this for over a year) I installed a fuel resistant hose between the tank and the passenger side rocker panel. From there to the fuel pump is normal steel fuel line...
The rear section was rusted and leaked, that's why I (again: temporarily) installed a hose..... it's been there long enough, time to get the "real" fuel line installed.
Aren't these SS braided hoses made for fuel ? There's not even pressure on that line - only between the pump and the carb.
again : and:
Old Jun 20, 2006 | 10:01 PM
CGGorman's Avatar
CGGorman
That's 5/8! Hell, your bathtub faucet only uses 1/2! You should be able to pump 15 gallons per minute through that at less than 50 psi. Unless you are running alcohol and pushing serious HP, -10 is just overkill to the extreme. The L88 and ZL1 engines managed to lumber along with 3/8 (-6) line at 6 psi.
Old Jun 20, 2006 | 11:26 PM
myoriginal77's Avatar
myoriginal77
Me too, never had a problem with mine.
Old Jun 21, 2006 | 01:36 AM
Victor's Avatar
Victor
1) I used Russel "Proflex Hose" http://store.summitracing.com/egnsea...t=RUS%2D632090
2) To attach to the sending unit I used a 2" piece of rubber tube from the sending unit to a socketless tube fitting from Aeroquip http://store.summitracing.com/egnsea...=AER%2DFBM1512. From that piece, I used a -6 AN coupler http://store.summitracing.com/egnsea...=AER%2DFBM2052 and then I attached my braided line to that.
Originally my '79 had a 2" piece of rubber tubing running from the tank to the fuel line so I'm not worried about the safety of the setup. It worked like that for 27 years without a problem.
My original plan was to cut off the nipple from the sending unit, install a 3/8" to -6 AN flared fitting. However, after cutting off the nipple from the sending unit, I discovered that there isn't enough room to slide the flared fitting back down the sending unit tube to use a flaring tool. So in the end, I had to buy a new sending unit.
3) The mechanical fuel pump that I'm going to be using doesn't have provisions to install a return line so I just left the return line tube on my sending unit open.
Hope that helps
Old Jun 21, 2006 | 01:46 AM
Corey_68's Avatar
Corey_68
I'm making around 600hp +/- and never miss a beat even at 6800rpms...
Old Jun 21, 2006 | 02:23 AM
Z-man's Avatar
Z-man
-10 would really be pushing it. I ran -8 all the way from the tank to the engine and back through a return line. There were some places where it *just* fit. -10 would be a tight squeeze unless you didn't run the line in the stock locations. Here's how I ran mine...
By the way, there is absolutely no gas smell associated with my setup.
http://temp.corvetteforum.net/c3/zma.../FuelSys02.htm
Old Jun 21, 2006 | 08:55 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
I run -8, it wasa tight fit but it follows the stock routing just fine. -10 would be a nightmare me thinks
Old Jun 21, 2006 | 09:09 AM
pws69's Avatar
pws69
ONLY if you do a lousy job and the connectors are leaking!
To what prevents me from
Old Jun 21, 2006 | 11:37 AM
68 NJConv 454
I've seen members squeeze -6 to carb and return line along passenger side frame? Can you squeeze -8 same way? I'd like to avoid running hose down pass side then back along driver.
Also, can you run -8 to carb and -6 return line? since you won't be returning as much fuel as you pump to the carb.
Old Jun 21, 2006 | 07:11 PM
Guru_4_hire
Cruise-In V Veteran
http://www.racepumps.com/fuel_system...00hpBoost.html
I could probably pull of a -8 line, but might as well only do it once.
Old Jun 21, 2006 | 10:26 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I used Aeroquip socketless -8 hose in the stock location tank to motor. -10 would be tight....
