That's indeed how it's supposed to be, the crossmember has 2 "notches". The wide one on the back (engine side) is offset from the center of the crossmember. The big hole and the small hole in the front face of the crossmember are exactly centered. Look how nicely your pulley sits in the wide notch..it's perfectly positioned.
